Tachometer is boucing randomly
Old May 22, 2005 | 12:33 PM
Chuji's Avatar
Default Tachometer is bouncing randomly
Sometimes when accelerating my tach bounces like crazy mainly between 3-4k rpms when I hit the gas it will fly up the redline and then back down rapidly. My fields vtec controller reads rmps and it remains steady and has no problem. How can I track down the short? Any suggestions?
Old May 22, 2005 | 12:50 PM
projectTeG's Avatar
check your ignitor and your grounds
Old May 27, 2005 | 06:22 AM
gabebauman's Avatar
Default Re: Tachometer is bouncing randomly (Chuji)
I just installed a 98 Integra Ls gauge cluster into my 98 Civic Ex and when I'm stopped/idle...with the turn signal on...the tach needle bounces to the rythum of the signal. What could cause this?
Old May 27, 2005 | 06:51 AM
chris23492's Avatar
Default Re: Tachometer is bouncing randomly (gabebauman)
check your distributor and wires on the plugs also check your grounds a bad ground can be bad news
Old May 27, 2005 | 07:11 AM
HoUTX98GSR's Avatar
Default Re: Tachometer is bouncing randomly (chris23492)
here... this is the second thread in 2 days on this.. try searching first...
heres a link to a fix
http://www.g2ic.com/tegtips/engine/10.html
Old May 27, 2005 | 07:45 AM
EFz6er's Avatar
Default Re: Tachometer is bouncing randomly (HoUTX98GSR)
same thing happened to me....I just removed the cap and made sure all connections were tight and it was fixed
Smash03
Jul 12, 2007 01:26 PM
99CivicSiBrian
Feb 24, 2006 03:32 PM
legendboy
Jun 24, 2005 10:03 AM
4door-r
Apr 23, 2004 04:01 PM
fred92htch
Nov 13, 2002 07:11 PM
