which is tach signal/tach wire - on distributor (obd-0) b18b
Old 01-16-2005, 01:28 PM
ejectseat's Avatar
Default which is tach signal/tach wire - on distributor (obd-0) b18b
what color is the tach signal wire on an obd0 b18b distributor? there are two plugs, one with 2 wires and another w/ nine. I need to know for a vafc hookup in a 2nd gen crx with an obd0 b18. The wiring harness is a disaster, so the signal won't be coming from there. It's for a friend, thanks for the help.
Old 01-16-2005, 02:51 PM
ejectseat's Avatar
Default Re: which is tach signal/tach wire - on distributor (obd-0) b18b (ejectseat)
help
Old 01-16-2005, 04:17 PM
BlueIntegraBoy's Avatar
If its like any other honda, the color is blue.
Old 01-16-2005, 04:41 PM
gsrteg97's Avatar
pop your hood ... there is a bundle of wires near the firewall on the drivers side .. in that bundle there is a blue wire that goes into a connector but does not go past the connector (youll know it when you see it) just unplug and connect and there you go
nonvtec
04-05-2005 11:11 AM
Dropped90Integra
01-13-2005 08:57 PM
ozzyman
09-29-2003 01:39 AM
ozzyman
09-29-2003 01:39 AM
ozzyman
09-28-2003 11:29 PM
Quick Reply: which is tach signal/tach wire - on distributor (obd-0) b18b
