SWAY BARS.....
Old Mar 21, 2007 | 02:39 PM
Nicks95GSR's Avatar
Default SWAY BAR.....STRUT BAR....
Im looking into buying a sway bar and a strut bar but I dont know if they sell some for the lower front. I know that they have a strut bar and sway bar for the lower rear, in the trunk, and for the engine. And what brand do you reccomend??? Does the brand make a difference?? Thanks HT Members!!!
Modified by Nicks95GSR at 11:07 AM 3/22/2007
Modified by Nicks95GSR at 11:10 AM 3/22/2007
Old Mar 21, 2007 | 02:57 PM
Micha's Avatar
FAILWGN
Default Re: SWAY BARS..... (Nicks95GSR)
Sway bars or strut bars?
Old Mar 21, 2007 | 03:03 PM
mrdeadman's Avatar
They let me pick
Default Re: SWAY BARS..... (Blu99teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote">Sway bars or strut bars? </TD></TR></TABLE>
Well if he's not a complete idiot I would assume he meant strut bars.
And if so, neuspeed, ITR, Password, and carbing are all good choices.
Old Mar 21, 2007 | 03:07 PM
Micha's Avatar
FAILWGN
Default Re: SWAY BARS..... (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">
And if so, neuspeed, ITR, Password, and carbing are all good choices.</TD></TR></TABLE>
You never know.
If he is asking for a front strut bar, I loved my neuspeed I had.
Old Mar 21, 2007 | 04:16 PM
IHTFP's Avatar
there are only two sway bars on your car, front and rear..they are the springy sort of flexible bars
there are also strut bars which connect the strut towers and something like a rear lower tie bar or something that you can get also. these are rigid and supposedly stiffen the chassis and prevent flexing
Old Mar 21, 2007 | 06:06 PM
dcRay's Avatar
you are an idiot if you never heard of a front sway bar.
Old Mar 21, 2007 | 06:13 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: SWAY BARS..... (dcRay)
sway bars=OEM ITR
strus bars=NRG, Carbing, Miracle X
Old Mar 21, 2007 | 08:12 PM
weaksoN!'s Avatar
hmm some ITR, DC, Neuspeed, are good brand name strut bars.
Old Mar 21, 2007 | 08:14 PM
WanaBeFaster's Avatar
Default Re: SWAY BARS..... (SlammedDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcRay &raquo;</TD></TR><TR><TD CLASS="quote">you are an idiot if you never heard of a front sway bar. </TD></TR></TABLE>
Yeah, but he also said lower front. I didn't know there was an upper and lower front sway bar. That's the confusion.
Old Mar 21, 2007 | 08:59 PM
98GSRDC2's Avatar
itr struts and itr sways ftw
Old Mar 21, 2007 | 10:04 PM
dcRay's Avatar
Default Re: SWAY BARS..... (WanaBeFaster)
notice he also said lower rear when he was referring to the rear sway. hence, lower front is front sway bar. anyway, like a lot of people suggested, you can't go wrong with front gsr/itr front sway bar and itr rear sway bar. A three point strut- carbing, passwordjdm, benen, or neuspeed bar will definitely yield better handling.
Old Mar 22, 2007 | 10:06 AM
Nicks95GSR's Avatar
Default Re: SWAY BARS..... STRUT BARS...
Thats the thing where do the sway and strut bars go? I get confused between those two.
Old Mar 23, 2007 | 10:23 AM
Nicks95GSR's Avatar
Default Re: SWAY BARS..... STRUT BARS... (Nicks95GSR)
Old Mar 23, 2007 | 10:48 AM
redGSRguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nicks95GSR &raquo;</TD></TR><TR><TD CLASS="quote">Thats the thing where do the sway and strut bars go? I get confused between those two.</TD></TR></TABLE>
Sways are on the bottom struts bars bridge the gap between your shocks.
Old Mar 23, 2007 | 11:20 AM
eze2079's Avatar
Default Re: SWAY BARS..... STRUT BARS... (redGSRguy)
I really liked my Beaks performance Rear Sway Bar set-up. Its a Stock ITR bar with a sub-frame reinforcement kit. This helps reduce the chance of ripping your lower mounting points when you use a big stiff bar. Also includes poly bushings. Its not super easy to install, but it makes a huge difference in getting the car to "rotate" in a corner. Before the install I had a hard time getting controlled oversteer on the track, but after the car was much more neutral.
Old Mar 23, 2007 | 01:16 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If the bar goes across the top, it's a shock tower brace. If it goes along the bottom, it's either a sway bar, or a tie bar. There are no lower shock braces.
Old Mar 23, 2007 | 02:29 PM
stolen_rims's Avatar
Default Re: SWAY BAR.....STRUT BAR.... (Nicks95GSR)
beaks is fine for subframe reinforcement(which you'll need if youre going to use a decently sized rear-sway), though the type of reinforcement beaks uses is not the same as the asr kit(which is probably the best reinfocement you can buy, but it doesnt come cheap). If thinking of going with beaks, I'd consider self-fab'n reinforcement yourself, and using the regular oem 22mm bar. Instructions can be found Here -&gt;http://www.geocities.com/bretq....html
as far as sway bars, theres the usdm oem 22mm type r you can get for around 50-65usd from most acura parts dealers. There's also the jdm oem 23mm type r you can get for about twice the price of the 22mm. Then theres the cusco 25mm rear sway that you can get for about twice the price of the 23mm.
as far as tower bars, go with one that mounts to the firewall as well, there's really 3 options I know of, 1)Carbing(best, imo, as it has a master brake cylinder brace built into it, and innertube reinforcement like the password bar is just overkill and unecessary weight) 2)password jdm(has stronger tubing, which is of negligable use) 3)Benen indust.(this company isnt in business anymore, but Im sure you could find their products somewhere, just dont expect any support if something doesnt work/fit.)
As far as "front" under bracing goes...you really dont need it, you wont notice it. But neuspeed, tanabe, cusco, carbing, and megan(I dont reccomend them) all make front under bars.
Old Mar 23, 2007 | 10:36 PM
Nicks95GSR's Avatar
Default Re: SWAY BAR.....STRUT BAR.... (stolen_rims)
Koo!! thanx HT members!!
Dubs13
Suspension & Brakes
11
Jun 22, 2008 04:56 PM
spaceman00
Apr 22, 2007 11:58 AM
haitian1
12
Feb 16, 2006 04:35 PM
Brown-tec
Oct 30, 2005 06:51 PM
EJ8 GSR-T
Apr 11, 2005 04:16 PM
