swap help
im back again...lol;......i want to know how hard do u think it is to install a b18c1 into a 93 teg ls...im kinda mechanicly sound,,,,,and also how hard is ti to do a auto to manual in this car....using cable tranny......and if u have n e wiring diagrams or n e thing to help my quest to have a vtec...plz hook me up!!!!!!
its going to become a quest since you need to convert from
automatic to standard
pedal assembly, 5sp ecu, pass side tranny mount
non vtec to vtec ecu
your car is a obd1 so you could use a obd1 P72 since you have secondary valves
and your wiring is to connect the vtec solenoid, oil pressure, knock sensor, sencondary valves.
you need your teggy driver side mount as well.
just some info hope it helps..
