Suspension question.....
ive read and read as much on the board as i can, and it has helped tremedously. I tried to search but nothing came up. I just recieved my neuspeed race springs today, and they will be matched with my tokico illuminas. Will i need to cut the bumpstop? Any other suggestions, please let me have them, i plan on doing these myself. Will i need a spring compressor?
TIA
TIA
I'm under the impression that Neuspeed doesn't want you to cut the bumpstops (even on their Race springs).
Spring compressor will make removing the stock spring easier, but you definitely won't need it to put the coilover assembly back together b/c the Race springs are so short.
. search around for an auto parts store that rents such equipment. some places refund your payment when you return the compressor.-jeremy
Check the papers that came w/ the springs, it should have something about cutting the bumpstops. My H&R Sport springs said to NOT cut my bumpstops, so I did not.
You'll definitely need a spring compressor if you're removing the stock springs/shocks assembly. I'd suggest you either try and rent one from pepboys. I've tried autozone and their spring compressor wouldn't fit into the thick coil stock springs.
The pepboys' spring compressor have the U-shaped hook that allows to slide it on first. If you can't rent one, you'll have to buy a set for ~$50.
HTH
HTH
Hope that helps ya.
SLowCrx
Dec 2, 2003 04:36 PM
