DIY suspension question...
Old 09-14-2003, 10:54 AM
teknikEG6's Avatar
Default DIY suspension question...
I currently have sprint springs on my car. I just recently purchased skunk2 coilovers. Do I really need a spring compressor to take them off? Any suggestions in how to do it would help..
Thanks
teknikEG6 is offline
Old 09-14-2003, 10:57 AM
racecarpete's Avatar
Default Re: DIY suspension question... (teknik_civic)
If you still had your stock springs then yes but you have aftermarket springs and probably won't need a spring compressor.
racecarpete is offline
Old 09-14-2003, 11:04 AM
handa's Avatar
When I used to have my stock spring on, me and one of my friends took it out and replaced it with coilovers without the use of a compressor. The method we used was if we dont' want your spings.
A method we used was jack up the car, heat up the spring really well with a flame welder until it gets red soft. Then bang it with a hammer several times until it break.
This method is dangerous and destroys your spring...but it's an another method.
handa is offline
Old 09-14-2003, 11:08 AM
teknikEG6's Avatar
Default Re: DIY suspension question... (handa)
yeah i dont think i want to do that. I already found someone to buy my springs im on. Thanks for the info guys....
Old 09-14-2003, 01:27 PM
mjrage's Avatar
Just pull your strut/shock out after taking off the bolts from top and bottom, step on the spring and use a wrench to take the top nut off. It will pop off under your feet.
I did this on my rear suspension last weekend without any problems. I even pushed down as hard as I could, and was able to get my springs back ON after I replaced the strut with an aftermarket shock.
With the coilover, you can also get them on, I had skunk2's on my last car and worked with them without any tools besides an impact and wrench.
mjrage is offline
Old 09-14-2003, 02:11 PM
kommon_sense's Avatar
Default Re: DIY suspension question... (SilverCivic2k)
Yes, you should use a spring compressor to be safe.
kommon_sense is offline
Old 09-14-2003, 02:43 PM
hoya_10fintec's Avatar
two giant visegrips work too..
hoya_10fintec is offline
Old 01-12-2006, 12:17 PM
racer_X_123's Avatar
Default Re: DIY suspension question... (hoya_10fintec)
also some ratcheting tie downs!
racer_X_123 is offline
Old 01-12-2006, 12:29 PM
x_outlaw_x's Avatar
this is by far the safest way to do it without a spring compressor...the nut on top that you use to pull the strut apart so you can take the spring off, just take that off while the car is sitting on the ground, then jack the car up and off the spring comes, and if it shoots off its going to go straight up to the hole where the top piece of the strut is
thats the way my autotech teacher taught us when our spring comopressor was broken
x_outlaw_x is offline
Old 01-12-2006, 12:35 PM
dohcVTECeg2's Avatar
Default Re: (x_outlaw_x)
spring compressor is a waste of money i think. there really is no need for it because it will come off without it. just put a towel over the shock/spring and loosen the bolt
dohcVTECeg2 is offline
Old 01-13-2006, 10:48 AM
Out of every
Default Re: DIY suspension question... (teknikEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">spring compressor is a waste of money i think. there really is no need for it because it will come off without it. just put a towel over the shock/spring and loosen the bolt</TD></TR></TABLE>
and then you can use the towel to wipe the blood when the spring pops out
just be safe and get the spring compressor. its not that expensive to rent
Out of every
Old 01-13-2006, 12:01 PM
x_outlaw_x's Avatar
rent it from autozone...26 dollar deposit...return it get your 26 dollars back
Old 01-13-2006, 12:02 PM
bebfsu1's Avatar
Default Re: (dohcVTECeg2)
I got mine for $12 shipped off ebay. I don't really think that's a waste of money. Plus I had to use them to put my lowering springs on the front because they were still not short enough for me to just put the nut on.
bebfsu1 is offline
Old 01-13-2006, 01:29 PM
jdmztrane's Avatar
Default Re: (bebfsu1)
If you go to Auto Zone (ricer store) you can rent a spring compressor with a down payment. Then when you bring it back they give you your money back.
jdmztrane is offline
96_Accord_lx
06-11-2008 07:28 AM
hatchy69
12
05-02-2007 02:05 PM
westminsterCA
Suspension & Brakes
03-19-2007 11:54 AM
Dee A Nine
Suspension & Brakes
08-29-2006 05:52 PM
Dee A Nine
08-29-2006 04:27 PM
Quick Reply: DIY suspension question...
  • Ask a Question
Question Title:
Description:
