suspension noise?
suspension noise?
It seems like when it's cold outside (i.e., in the low 30s or below), I seem to get a squeaky hinge type of noise when I hit a sharp bump at slow speed (under 20 mph). Usually (always?) the bump is hitting only one side of the car - half of a speed bump is a good example of what I'm talking about.
I was wondering if this is my polyurethane bushings on my front anti-roll bar? It sounds as if comes from - usually - the front left or right. (Although occasionally I think I hear something from the back.) I don't seem to hear it during warmer weather.
Any ideas?
Any ideas?
Re: suspension noise? (crr)
If i were you i would spray a **** load of WD-40 on an the coilover and bushings.. Basically anywhere you think its coming from.. Then test drive it. If i goes away good, if it doesn't proceed inspection.
