Suggestions?
Old Nov 22, 2006 | 05:08 AM
foxfai's Avatar
Default Suggestions?
My 94 LS is at 110k miles and had been thinking about changing my timing belt a while ago since I thought it was due at 90k.
I checked with Acura yesterday and they said the first timing belt change from their standard schedule isn't until 120k. Their 120k schedule maintaince consist alot of things, which total up to around $1500 or so.
What do you guys think? Should I do this for $1500?
Old Nov 22, 2006 | 06:00 AM
PrinceAli132's Avatar
Default Re: Suggestions? (foxfai)
I would take care of the timing belt asap. That is one thing I would not risk delaying maintenance on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . &raquo;</TD></TR><TR><TD CLASS="quote">7.5k-22.5k-37.5k-52.5k-67.5k-82.5k mile service
Change Engine Oil & Filter
Check Clutch Adjustment & Fluid Level
Inspect Front Brake Pads, Rotors and Calipers
Inspect Fluid LEvels
Adjust Parking Brake
Inspect Exhaust System
Inspect Tire Wear & Set Tire Pressure
Check hoses, belts & coolant level
check wiper blades & windshield washer fluid level
inspect power steering fluid level
inspect transmission fluid level
inspect front suspension & steering operation
rotate tires
15k/45k/75k mile service
Change Tranny Fluid
Replace Fuel Filter
Replace Air Filter
Inspect Front & rear Pads, Rotor & calipers
Inspect all fluid levels
adjust parking brake
inspect clutch operation, adjust freeplay and check fluid level condition
adjust all belts
inspect suspension mounting bolts for tightness
inspect exhaust system
inspect tire wear and set tire pressure
check hoses belts and coolant level
inspect battery and clean terminals
adjust alternator belt
inspect valve clearance
check wiper blades and winshield washer fluid
lube door, hood latches and hinges
rotate tire and balance
inspect and clean spark plugs
inspect cap and rotor
road test
30k/60k/90k mile service
Change Tranny Fluid
Replace Fuel Filter
Replace Air Filter
Replace Spark Plugs
Replace Distributor cap, rotor and inspect wires
set ignition timing and adjust cambelt
Inspect crankcase emissions
Inspect front & rear pads, rotors and calipers
Replace brake fluid, check hoses & lines
replace clutch fluid, clutch operation, adjust freeplay
adjust all belts & inspect power steering fluid
replace engine coolant & check hoses belts
check wiper blades and windshield washer fluid
Taken from here;
https://honda-tech.com/zerothread?id=217861
Find out exactly what they are including. Also, most of this stuff you can do yourself and is really simple even if you don't have alot of automotive knowledge. You can also find a friend to help you out and teach you how to do the the work you don't know how to to do, which will save you a lot on the labor.
Ali
Old Nov 22, 2006 | 09:29 AM
DC2_ALL MOTA's Avatar
Default Re: Suggestions? (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">I would take care of the timing belt asap. That is one thing I would not risk delaying maintenance on.
Taken from here;
Ali
x2
Old Nov 22, 2006 | 09:50 AM
Rikter's Avatar
Ditto on the diy. CHanging spark plugs, rotating tires, etc are all very easy if you've got a friend with tools or tools yourself.
Dealerships will change maybe $40 in labour just to change some spark plugs which anyone with half a brain can do on their own for hte price of hte plugs (maybe 15ish bucks).
I'd do what you can, then take it in and let the dealership know what stuff doesn't need to be done because you've done it yourself and cut that bill in half.
-RIk
glenmore
Acura TL, RL & ZDX
May 25, 2012 11:18 AM
Ms.JDMdb8
Jul 9, 2005 06:34 AM
Hehehe I just
Jan 25, 2004 12:41 AM
Campee
Apr 2, 2003 09:32 AM
uNF$@#!
Mar 1, 2003 08:10 PM
