stuck shift linkage
Old Sep 26, 2013 | 12:17 PM
Dr.Fixit's Avatar
Default stuck shift linkage
hey everyone, I'm in the process of swaping a tranny over and replacing the shift linkage as it's all rusted. I have the pin removed holding the shift linkage to the tranny but it seems to be stuck on. I don't wanna beat on it, in fear of messing the gears up or something internal on the trans. Anyone have an idea's as to how i could get it out or a safe way to remove it? Any help is much appreciated! thanks!
Old Sep 26, 2013 | 12:30 PM
B_Swapped93's Avatar
Default Re: stuck shift linkage
Is it JUST the lower rod that's left on there ? you can hammer around where the pin comes out with out doing damage. my guess since you say rusted it's fused in a sense and needs to be hit
Old Sep 26, 2013 | 01:23 PM
Dr.Fixit's Avatar
Yes, just the one lower rod is left. I had the pin removed before and had just replaced it with a bolt so I didn't have to deal with the pin. It should just come off now since nothing is holding it on. I just wasn't sure if it was safe to hammer it off or not and didn't wanna take the chance of breaking something inside the tranny.
Old Sep 26, 2013 | 03:35 PM
90_EX_Civic's Avatar
use a rubber mallet or a brass hammer.
Old Sep 26, 2013 | 05:11 PM
TheRealTegger's Avatar
Do you have a small C-clamp? Use that to squeeze the linkage where the pin used to be. Do that from several locations around the rod.
Rust is very brittle. Squeezing and releasing the rod should break up the rust to the point where you can wiggle/twist/slide the rod off the shaft inside the transmission.
Old Sep 26, 2013 | 06:21 PM
oh, forgot to add, spray it down with pb blaster
Old Sep 27, 2013 | 10:39 AM
Dr.Fixit's Avatar
Is it safe to try and seperate the tranny and bottom shift linkage rod by using a hammer though? i sprayed some wd40 on it already. I'll try some pb blaster next.
Old Sep 27, 2013 | 12:00 PM
wd40 is just a degreaser. you want something that will break the rust down, like pb. other guys use something else, but the name eludes me.
and if you use a rubber mallet, or brass hammer you should be fine.
if you're still scared you could just spray it down with pb, and then grab the rod and just try to spin it. if the shifter is unbolted and the pin is out, it should just spin.
Old Sep 27, 2013 | 01:28 PM
Dr.Fixit's Avatar
I was gonna give some of that white lithium ion grease a try, I'll have to go get some pb blaster. I'd rather be safe then sorry. Just wanted to get some more idea's/opinions before I started beating on it lol. I like the idea of trying to spin it though. haven't tried that yet. I'll give it a shot and see what happens.
Old Sep 27, 2013 | 02:36 PM
lithium ion grease is just a lubricant. need something to penetrate the rust. to break it down. if you had a torch you could heat the linkage up a little and twist. see if it'll break, the rust
Old Sep 27, 2013 | 04:26 PM
Pics of rust OP ? the PB blaster and rubber mallet should do it.
Old Oct 2, 2013 | 09:59 PM
Dr.Fixit's Avatar
I ended up doin some drilling and got it detached for the most part. I'll post some pics soon. Also does anyone know where I could get the shifter pieces 7,8, and possibly 11 in b swapped93's picture posted? I see that they sell just the shift linkage rods for like $134 ish or the entire thing for $300. I'd rather not pay that much if i can just get the missing pieces since I got mostly everything else I need.
Old Oct 3, 2013 | 03:03 AM
NVturbo's Avatar
O.G. triple O.G.
heavy *** hammer and a CARRIAGE BOLT the same diameter size as the pin. The carriage bolt works better than a center punch.
Old Oct 3, 2013 | 07:12 PM
skill178's Avatar
this is why I always knock the pin out and then put the car into 3rd gear to knock the bar off before removing any other bolts...
Old Oct 3, 2013 | 09:17 PM
7,8, and 11, go to honda, especially for the plastic piece.
linkage, just go to a junkyard.
Old Oct 20, 2013 | 05:36 PM
beren's Avatar
10 Year Member
I just got mine off today. I had to use an acetylene torch to get it hot but shielded the seal and rubber protector. Beating it back didn't work, I had to lock the u joint by twisting the bar and using that to break it free twisting back and forth. Good luck. Hope I didn't break anything in my tranny...
Old Oct 21, 2013 | 04:17 PM
hondalike's Avatar
Jack the car as high as you safely can, get a short handle-heavy hammer and a pair of needle nose vise grips with a screw gun bit. The one I use tapers to a square end. This locks it into the rolled pin and will follow it all the way out. As pictured. Unless you have an air hammer it's the best way I've found.
Old Oct 21, 2013 | 08:37 PM
not to come off as a ***, but could have just got a roll punch.
others have used a a/c mounting bolt.
Old Oct 22, 2013 | 12:42 AM
hondalike's Avatar
Like the bit better because it's shorter where every cm counts when swinging the hammer. I like it better than the bolt too. But your right as there are many posts addressing this issue.
AViciousTHRUST
Dec 6, 2006 12:11 AM
stegon78
Jun 24, 2005 08:46 AM
Aespooncivic
May 7, 2005 09:23 PM
cincispeedemon
Oct 9, 2004 02:55 PM
MR. MIYAGI
Mar 12, 2004 12:34 PM
