Stuck in reverse
Old Oct 2, 2011 | 04:13 PM
bostonhusky's Avatar
Default Stuck in reverse
Hoping someone might have some insight into this -
2001 integra w/ 98k, A/T. Wife pulled into driveway yesterday, tried to shift into park and got stuck in reverse. No noises, just stuck. Now I can't get it out of reverse. Driveway has slight grade - I tried rocking the car forward and then have her try to shift out, no luck. Any ideas?
Old Oct 2, 2011 | 04:22 PM
TeamHackura's Avatar
Default Re: Stuck in reverse
check linkage
Old Oct 2, 2011 | 05:11 PM
fcm's Avatar
fcm
Old Fart
Ditto the above, jack her up, USE JACK STANDS, and get under her and check all the linkage... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal .94
Old Oct 3, 2011 | 02:14 AM
Thanks for the responses, will check it out.
Old Oct 3, 2011 | 06:04 AM
ssoRUF's Avatar
Does the car have a release next to the shifter? Usually you can stick the key in there and it will release the lock on the shifter.
Old Oct 3, 2011 | 07:29 AM
fcm's Avatar
fcm
Old Fart
The shifter is not locked into park it is locked into rev., the park lock should not have any effect other then in park.
However, stranger things have happened, if linkage looks OK, then I would pull the console and have a look at the shifter itself, even a coin dropped in there could jamb up the shifter, or maybe something broke. 94
Old Oct 10, 2011 | 08:00 AM
I ended up pulling the console apart and lubing up everything I could, including the park lock/release mechanism. That seemed to do the trick for the time being. It's still a little stiff between park and reverse, but any gear shift after that is smooth.
JDMPR
Sep 21, 2009 06:11 PM
honda2ksi
Transmission & Drivetrain
Apr 15, 2009 08:52 PM
aznej2
Mar 16, 2008 01:29 PM
tommyleeruiz
Jul 20, 2007 04:49 PM
G0crxG0
40
Apr 24, 2006 07:14 AM
