Strange Noise.....
Strange Noise.....
My friend's GSR makes a loud grinding noise from 3000-4000 RPM. The noise continues through till she passes 4000. The engine is stock and it has and Exedy clutch. Does anyone know what it could be, thanks.
-Brian
-Brian
Re: Strange Noise..... (BigTymer19)
yeah, it's probably just vibrating and hitting the exhaust manifold. nothing is wrong with it (assuming that it is the heatshield).
some people also say it's the a-pipe (the pipe between the exhaust manifold and the cat). if that's the case, it's an internal error with an acura part, which i don't know how to fix other than replace the a-pipe.
Re: Strange Noise..... (integra15)
I have a 99 gsr with the same problem, i took off the heat sheild around the cat thinking that was the prob, buy it still does it. My friend told me it that it was the A pipe and i needed to get a new header.
