Steering problem
Old May 9, 2006 | 03:43 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default HELPPP!!!! I have a Steering problem
my 1990 integra has a steering problem..
-you can turn left, and it makes a few clicks when you turn it as far as you can
-you can't turn the wheel right after it's reached the middle point..
it's kinda hard to explain.. but if you guys know what im talkin about just post. and i'll try to describe it better
Modified by ohsnapzafingcu at 4:58 PM 5/9/2006
Old May 9, 2006 | 05:27 PM
Default Re: HELPPP!!!! I have a Steering problem (ohsnapzafingcu)
someone please helpp or bump this thread if they kinda have a clue of what i'm talkin about
Old May 9, 2006 | 05:32 PM
__oversea's Avatar
check the axle, bars, street rack, look for any bent or missing bolts, crack, dis enguaged.
Old May 9, 2006 | 05:39 PM
Default Re: HELPPP!!!! I have a Steering problem (Last For One)
axle is good, there was a bolt missing but i couldn't see where it bolted down too
it turned with the wheel when it felt 'unconnected' (when the wheeels wouldn't turn when i turned the steering wheel)
Old May 9, 2006 | 05:43 PM
Wayne_Curr's Avatar
a flat spot in the rack maybe? thats really weird, i'm tryin pretty hard to figure out what would cause that mechanically.
Was your car stolen? Any damage done to the column?
Old May 9, 2006 | 06:04 PM
Default Re: HELPPP!!!! I have a Steering problem (Wayne_Curr)
i'm tryin to figure that out too.. i just purchased it yesterday thinkin it was gonna be easy to fix, turns out it isn't so easy.. they guy was trying to pull the motor out and he disconnected everything that had it before
other then that, it starts and idles great
Old May 11, 2006 | 05:13 AM
there's a pin/bolt/plate under the car that is disconnected... i can't quite get under the car, but who has an idea of what it is?..
if anyone has a picture that shows all the parts of the steering column or something close to that postt it. couldn't find anything on google
r22thomas
11
Aug 10, 2011 12:24 PM
rachonda
Jul 5, 2007 06:54 PM
panda
Jun 28, 2003 11:25 AM
jdmrealm
Jun 25, 2002 04:59 PM
