starting problems need help asap!!!!!!
Old Apr 30, 2009 | 06:07 PM
viciousef9's Avatar
Default starting problems need help asap!!!!!!
ok my bro has a 90 integra with a obd-0 swap in it. he has the ecu and distributor both. he says that the car it cranking but not starting im not sure if its from the dizzy goin out or what, he also said the ground wire in the top of the valve cover was loose and beat up. i know this has a lot to do with starting. but im not sure if thats the only ground. some one please help asap. thanks
Old Apr 30, 2009 | 06:18 PM
viciousef9's Avatar
Default Re: starting problems need help asap!!!!!!
anyone???
Old Apr 30, 2009 | 06:19 PM
MD426's Avatar
OBD0 swap in a 90? 90-91 DA Integras were OBD0 to begin with. Is there any spark? There is more than one ground then just on the valve cover. Make sure the plug wires are in the right firing order, timing is good, and the distributor is adjusted right.
Old Apr 30, 2009 | 07:18 PM
viciousef9's Avatar
i know that it is obd-0 to begin with just giving all the info to jjust in case certain question were asked. he just went to inline 4 and bought a new dizzy cap, rotor, and ngk blue spark plug wires. the last thing he is having a problem with is the ground on the valve cover. thanks. anything else it could be?
Blue-EM1
Feb 19, 2009 04:05 PM
gxiang
Apr 30, 2007 06:50 AM
crxforum
Apr 22, 2007 01:34 PM
pokemon master
Aug 8, 2006 09:58 AM
just4747
Sep 4, 2004 12:52 PM
