Starting Problem
Old May 7, 2003 | 05:32 PM
Senbonzakura's Avatar
Default Starting Problem
Its not really a starting problem its just that everytime I start my car, whether its in the morning, afternoon, or anytime I start it. My RPM jumps to 2. Usually and isn't it suppose to be at 1.5 or 1? Then when I move the steering wheel while its warming up, the RPM jumps like 4 marks. Anybody know whats the problem? How I fix it also? Thanks
Old May 7, 2003 | 06:12 PM
bengeeee's Avatar
We'll. As a general rule 800 rpm is a good idle speed. Your throttle plate could be stuck somehow. There is a pin you can adjust it with. I'm not too sure how to do that but someone on the forum should know. I have no idea why it would jump to 4k rpm tho. Thats scary. Unless you mean it just went up 4 ticks. Im not too sure what you meant. Anyways, are you throwing any check engine codes? Im not too sure what it could be. Anyone else wanna help him out. I wasn't much help i guess.
Ben
Old May 7, 2003 | 06:15 PM
Default Re: (bengeeee)
Nah it didn't jump up to 4RPM. I meant it jumped like 4 ticks yeah. Some people say I have a vaccume leak. Whatever the hell that is..anybody know what it is and can help me solve it?
Old May 8, 2003 | 07:31 AM
JimBlake's Avatar
Default Re: (Kyo Kusanagi)
Look for vacuum hoses that are disconnected, or maybe a leaking gasket on your intake manifold or throttle body. There's vacuum in your manifold, and if something's leaking it lets air in thru the leak... that's a 'vacuum leak'.
Old May 8, 2003 | 07:37 AM
NeoGSR's Avatar
Default Re: (JimBlake)
it's normal for the RPM's to jump a bit when you turn your steering wheel....but a 2k idle seems a little high....
PhilMac
Jun 17, 2007 02:09 PM
yee SERIOUS
Apr 17, 2006 01:58 PM
^MikeG
Nov 25, 2004 11:30 AM
zm_dawg
Aug 8, 2004 05:24 PM
redacura
Jul 18, 2002 11:53 AM
