starting problem
Old Aug 11, 2008 | 04:24 PM
b20racer's Avatar
Default starting problem
tell me why, when i come out in the morning my car starts up fine, but when it warms up it pops a check engine, still runs fine when the check engine is on, but when i turn the car off it wont start again until it cools off, also if it sits out in the sun for a while, it wont start, whats the problem?
Old Aug 11, 2008 | 07:27 PM
Jimmy's Avatar
Global Moderator
Default Re: starting problem (b20racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20racer &raquo;</TD></TR><TR><TD CLASS="quote">tell me why, when i come out in the morning my car starts up fine, but when it warms up it pops a check engine, still runs fine when the check engine is on, but when i turn the car off it wont start again until it cools off, also if it sits out in the sun for a while, it wont start, whats the problem?</TD></TR></TABLE>
Have you pulled the CEL it's throwing?
When it doesn't want to start.. do you hear the fuel pump priming?
https://honda-tech.com/zerothread/1901557
Old Aug 11, 2008 | 07:48 PM
b20racer's Avatar
Default Re: starting problem (Jimmy)
no i havnt check it yet, but i also heard that it could be my main relay but i dont think that would throw a check engine light, or mabey my fuel relay.
Old Aug 11, 2008 | 07:56 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20racer &raquo;</TD></TR><TR><TD CLASS="quote">no i havnt check it yet, but i also heard that it could be my main relay but i dont think that would throw a check engine light, or mabey my fuel relay.</TD></TR></TABLE>
yep, that's i asked..
If you do not hear the fuel pump it is most likely your pgm-fi main relay.. the joints in the relay get dry and crack causing bad connection.. You can pull the cover off and re-soldier the joints or buy a new relay.
Old Aug 11, 2008 | 08:05 PM
b20racer's Avatar
i have a 91 da, is that cel # list for my car also.
Old Aug 11, 2008 | 09:20 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20racer &raquo;</TD></TR><TR><TD CLASS="quote">i have a 91 da, is that cel # list for my car also.</TD></TR></TABLE>
****, i was assuming u had a DC integra (94+)
No i'm not sure, i don't believe it is the same..
i can try looking on team-integra
Old Aug 11, 2008 | 10:39 PM
b20racer's Avatar
if you can that would be cool.
osbunjosh
12
Mar 3, 2013 12:20 PM
bpetruzzo
Jan 8, 2008 05:48 PM
eg6madness
14
Jun 15, 2006 07:48 PM
bust
May 13, 2006 11:58 AM
jdmDAsix
Aug 10, 2005 01:01 PM
