starting issue can u help ?
Old Mar 14, 2012 | 12:02 PM
hondafan16's Avatar
Icon2 starting issue can u help ?
when i go to start the car it dont want to run but if i give it gas when starting it fires up but then i kinda gotta stay on the throttle for a few seconds for it to stay running but then its fine. car has been sittin a lil bit i threw a rod n swapped this b18b1 in an this is how it starts ?
Old Mar 14, 2012 | 06:30 PM
el crapitan's Avatar
Default Re: starting issue can u help ?
what year is the car? what year motor?
Old Mar 14, 2012 | 06:58 PM
Dioxine's Avatar
If after you have it running and shut it off for a few minutes will it start right up? If its a sitting overnight thing then it sounds like fuel flooding.
Old Mar 14, 2012 | 09:47 PM
Dc4LsTeG's Avatar
EK9
Any vacuum leaks? When's the last time you did a tune up?
Old Mar 14, 2012 | 10:10 PM
fcm's Avatar
fcm
Old Fart
Try this, turn the ign. on to the run position, not start, and wait till fuel pump stops priming and CEL goes out, turn ign. off and then on to run again, again wait untill pump stops priming and CEL goes out, and cycle ign. switch again, do this 3-4 times, on the 4th time, when fuel pump stops priming, try and start the car, what happens, engine starts, [without touching gas] you still have to "give it gas", [nothing changed]? 94
ttcheung97
Aug 24, 2020 06:31 AM
rjbiii
10
Sep 24, 2011 12:29 PM
KevinEvo
Aug 17, 2010 08:08 PM
goldenmustache
38
May 13, 2009 07:04 PM
BlueLude84
Jan 13, 2007 10:11 PM
