Starter replacement
Old Aug 20, 2003 | 06:02 PM
Battousai TT52's Avatar
Default Starter replacement
The starter on my 94 auto ls teg is going on me. Is this a easy DIY fix and how much should i be able to get on from a junkyard for? Any advice/links would be appreciated
Old Aug 20, 2003 | 08:08 PM
tegmaniac's Avatar
Default Re: Starter replacement (Battousai TT52)
try taking it to starter rebuild shop. It may just need new brushes like mine did. It is definitely a do it yourself job. Just don't forget to disconnect the battery.
Old Aug 20, 2003 | 08:24 PM
Default Re: Starter replacement (tegmaniac)
WEll somtimes when i go to start it will just click. and click then after many tries it starts right up. how much did what your talking about cost?
Old Aug 20, 2003 | 08:32 PM
mickey513's Avatar
I got a rebuilt one for my 94gsr from a local starter/alternator shop for $90 with 1 year warranty.
Old Aug 20, 2003 | 08:34 PM
Default Re: Starter replacement (mickey513)
Cool hopefully I'll be able to handle this little inconvenience with 100 bucks or less
Old Aug 20, 2003 | 08:57 PM
Vinny Chase's Avatar
I got mine for $120 at my auot parts store, its rebuilt and has a warranty as well, took me an hour to install.
Old Aug 21, 2003 | 09:44 AM
Default Re: Starter replacement (Vince10984)
Bump for the day shift.
EDIT: anyone know what part is bad that makes it click over and over? or would i be better off getting a whole new starter?
Old Aug 21, 2003 | 10:22 AM
I found a used starter for 95.95 on the web any know where i can find a write up on how to cahange one and how long it should take?
Old Aug 21, 2003 | 01:30 PM
StyleTEG's Avatar
It is really easy, if you know where it is you can replace it.
Its held on by only two bolts, a ground, and one electrical connector. It took me about 20min to do it for the first time.
Old Aug 21, 2003 | 02:01 PM
mingchi69's Avatar
I to Smooch Pickle
buy a remanufactured one from autozone.. or oreilly.. they come with a lifetime warranty.
Old Aug 21, 2003 | 03:00 PM
xteg95's Avatar
Default Re: Starter replacement (mingchi69)
you can get them from 50-70 @ http://www.car-part.com , install is really easy
Old Aug 21, 2003 | 03:53 PM
MightyMouseTech's Avatar
There are three brands of Honda starters. If you have a Nippondenso (I am pretty sure this is the one) then you can just replace the starter contacts inside. It is a $10 fix. Most Honda dealers will have the contacts in stock. It is also only a ten minute job once you get the starter out. I have been working on Hondas/Acuras for quite a while, and I have never had to replace a starter motor, only replace the contacts. It seems like the only ones that have problems are the ones that you can get contacts for.
Old Aug 21, 2003 | 06:57 PM
tegmaniac's Avatar
Default Re: Starter replacement (MightyMouseTech)
I agree with mighty mouse. I only paid 40 for the brushes installed. If you can do it yourself then it will be even less
Old Aug 23, 2003 | 02:53 PM
bump more info is needed. Im calling the acura dealership monday when i get out of class.
Old Aug 23, 2003 | 08:09 PM
i will bump one more time cause im realy hopin for some help here
Old Aug 23, 2003 | 08:49 PM
xteg95's Avatar
are they any local shops around you? i got one from a shop for 50...what other info do you need?
Old Aug 23, 2003 | 09:18 PM
eyesonlybob's Avatar
just go to checker and buy one. my brothers 86 honda accord was clicking, and then starting after a few tries. i took the starter off, and it looked like it could use replacing. bought a new/refurbished one for $110. took about an hour to get the old one out and the new one in
Old Aug 24, 2003 | 12:14 AM
Default Re: Starter replacement (xteg01)
where are you people buying them from? i go to autozone and **** and they wat 156 and up. and im trying to get out of this for under a hunderd. the cheaper i can do this and do it right the better. Being a broke college student i do have limitations on cash.
Old Sep 9, 2003 | 10:46 PM
Jolf's Avatar
I never knew this was such a problem. I just had the pleasure of paying to have mine replaced since I didn't have time to do it myself.
Old Sep 10, 2003 | 07:04 PM
90njteg's Avatar
Banned
Default Re: Starter replacement (Jolf)
bump, I got the same problem with my 94 ls, I get a few clicks b4 it finally turns over, stupid starter......
Old Sep 11, 2003 | 07:01 AM
SupaTegRS's Avatar
Default Re: Starter replacement (90njteg)
I have the same damn problem.....does anyone have a diagram of exactly where the starter is? I'm 80% sure that i found it, but just wanna make sure.
Old Sep 11, 2003 | 10:07 AM
PnX-R's Avatar
I gave a quick little theory as to what causes starting problems in this post. Just a little something I picked up from class. It's the last post in the thread. https://honda-tech.com/zerothread?id=426323
Hope it answers your clicking question.. Good Luck..
Old Sep 13, 2003 | 04:06 PM
SupaTegRS's Avatar
Default Re: Starter replacement (PnX-R)
well, i just replaced my starter today.....car started on first try Was really simple to do too. If anyone has any questions, send me a pm....I can help walk ya through it.
onunezp
Aug 3, 2015 10:28 PM
big.turbo.daddy
Jun 23, 2015 06:34 PM
robot.reed.o
Mar 11, 2009 06:33 AM
crxaddikt
Dec 5, 2007 12:31 PM
