Starter Problem
Old Nov 10, 2005 | 01:06 PM
pearlteg's Avatar
Default Starter Problem
as topic says whenever am low on gas and i shut my car off for a little bit then turn it back on my car would crank but have a hard time starting. then when i wait a few min it wil start fine and remind that i try to start it once and while inbetween the break. it also happened when i was low on fuel and i filled up right after i wouldnt start. could it be my fuel injectors being dirty, or starter problem
Old Nov 12, 2005 | 10:12 PM
ATS_Antone's Avatar
Default Re: Starter Problem (pearlteg)
your story kinda jumps around and is hard understand whats happening.
fix it and i bet you will get alot more responses. g luck
Old Nov 12, 2005 | 10:15 PM
Lord Helmet's Avatar
check your entire fuel system over and igniton system. sounds like a fuel system issue though.
Old Nov 12, 2005 | 10:19 PM
JDM-EJ1's Avatar
Default Re: Starter Problem (Lord Helmet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote">check your entire fuel system over and igniton system. sounds like a fuel system issue though. </TD></TR></TABLE>
Maybe a spark issue too.. This happened on my Accord, it turned out to be my dizzy.
lcraigapny
Honda CR-V & Element
Jun 29, 2018 03:59 PM
spore691
Nov 3, 2012 08:44 AM
lude98SH
Oct 1, 2007 06:15 PM
sweetcarz02
15
Nov 2, 2004 06:40 PM
urbanlegend21
Aug 31, 2004 04:04 PM
