Starter Issue?
Old May 13, 2008 | 04:18 PM
ninety-five_DB's Avatar
Default EDIT: Possible Distributor Problem? (Originally Starter Issue?)
yO, what up HT.com
Lookin' for some light to be shined on me from hopefully some or at least one of you knowledgeable honda heads.
Here's the issue: Car doesn't start. When turning the key in ignition motor does not turn over or crank at all. All i'm getting is a "click" each time. I was told by a local mechanic to take the "butt-end" (not too clear if that's what i remember) of a hammer and tap the starter while someone else tries to start the motor. Just wanna know more on this before I move on to possibly spending money to buy replacement parts.
-Okay...tried tappin' the starter and teg didn't start. So not likely the problem. Did notice the "click" noise which sounds like its coming from the dizzy. Anybody have a similar issue before?
Long Story: Integra has a Viper 791XV system installed w/ Automatic start. 1 day the alarm tripped on me. I tried turning the car off and the motor started choking as if it were starting repeatedly (really, the only way i can describe it). Ever since, car hasn't started and sat in garage for over a year. Trying to fix problem with tax refund $$$.
Modified by ninety-five_DB at 6:16 PM 5/13/2008
Old May 13, 2008 | 04:30 PM
Hedi422's Avatar
Default Re: Starter Issue? (ninety-five_DB)
try it i have started many of cars doing it like that, it should start if it indeed is the starter
Old May 13, 2008 | 04:33 PM
mayoforlife2's Avatar
Default Re: Starter Issue? (Hedi422)
X2yes try that first if the starter is still clicking, then i would go head and replace it . goodluck! make sure you disconnect the battery when you replace!
Old May 13, 2008 | 04:40 PM
Default Re: Starter Issue? (mayoforlife2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mayoforlife2 &raquo;</TD></TR><TR><TD CLASS="quote">X2yes try that first if the starter is still clicking, then i would go head and replace it . goodluck! make sure you disconnect the battery when you replace!</TD></TR></TABLE>
thnx...yeah that was the first tip i got if i'm going to replace the starter.
BlueVxIDelSlo
Apr 6, 2011 06:29 PM
johnwohl
Sep 17, 2009 03:12 PM
Daguy418
Aug 3, 2005 04:21 PM
RUBZERK
Sep 18, 2004 05:13 AM
Bklyn TSi
Sep 22, 2001 09:12 PM
