Start up issue
Old Jun 8, 2010 | 03:33 AM
Domnificent's Avatar
Icon6 Start up issue
Okay my teg has been sitting up for a month mainly because i sold the wheels off of it and last night i got some more and when i go to start it up and nothing happens so we checked the battery and decided to jump it off and it starts up but the engine wont turn over.. So what could the issue be? what do i need to check next??? oh and also my bro had the brilliant idea of trying to check the spark plugs but he broke one off so whats the best way to remove the bottom of the spark plug from its home??
Old Jun 8, 2010 | 06:07 AM
Dwizzy's Avatar
Default Re: Start up issue
Do you mean the clip got stuck in the dizzy? if so you should be able to pull it out with your fingers or pliers. What happened when you checked the battery? was it dead?, Did you check for spark with the other wires? What does it sound like when you try to start it? do the lights come one? Going to need a little more information man.
Old Jun 8, 2010 | 07:46 AM
Yes the battery was dead but its working now and the lights and cd player and all that works now and it made the sound like it was trying to crank i dont know how to explain it.. But the engine just wouldnt turn over, it almost did once but like 3 times after it didnt again
Old Jun 8, 2010 | 08:50 AM
Dwizzy's Avatar
did you test it for spark? so it does turn over it just want start correct? or does it just make a ticking sound when you try to crank it, because in the OP you said it wouldn't turn over.
Old Jun 8, 2010 | 07:04 PM
vroomvroomparty's Avatar
Check your ground and positive connections on the battery. If it's not starting it could be a fuel issue as well. Make sure youre getting spark and fuel, if you are, then check the intake manifold. Check all vacuum hoses, IACV, if your car is 93 and under check your FITV as well. If all of these check out, it may be a timing belt problem, may have skipped some teeth or even snapped. Let us know, good luck.
Old Jun 12, 2010 | 02:55 PM
Yes i jus got some E3 spark plugs today and we are going to put em in in the morning and see how it goes from there
sd_ej1
Oct 25, 2008 06:51 PM
BS 22
Jun 19, 2007 02:03 PM
zacatkings
27
Mar 22, 2006 05:26 AM
mr devious illusions
May 20, 2005 09:56 PM
ace42004
34
Apr 11, 2005 02:57 PM
