Start up delay
Old Aug 21, 2010 | 04:18 PM
ninjaturtleEG's Avatar
Default Start up delay
When I turn the key to the start position and hold it there, nothing happens for a few seconds and then it starts. At first it was just a couple seconds but this morning i had to hold it there for at least 10 seconds until the car started. When I mean nothing happens I mean nothing, the cars not cranking. Is it a bad connection somewhere? Oh and Ive been trying to figure out when this happens, but it just seems to happen on and off. It seems to only happen when I leave it sitting for awhile(overnight) and then throughout the day when I'm running errands theres no startup delay. Any thoughts?
Old Aug 23, 2010 | 12:47 AM
xxjimmyboixx's Avatar
Default Re: Start up delay
the only thing i can think of is the battery or starter. my ej had a delay once in a while when i turned the key, and sometimes it doesnt start at all. u can take it to auto zone and they will check it for free. and while ur there check everything else u can think of
Old Aug 23, 2010 | 12:53 AM
can u hear a click when u turn the key?
Old Aug 23, 2010 | 05:32 AM
fcm's Avatar
fcm
Old Fart
The ign. switch is most likely the problem... http://www.visualimpressions.ca/switch/
http://techauto.awardspace.com/ignitionswitch.html
To confirm it is not the starter motor do a "by-pass" jump, unplug the starter lead from the starter solenoid, using a jumper lead with one end connected to the batt. pos.(+) post, touch the other end of jumper lead to to the solenoids starter terminal, BE CAREFULL engine WILL crank even with ign. switch off and car in gear, make sure car is not in gear and hand brake is set. 94
Old Aug 25, 2010 | 12:02 PM
Ya I'm thinking ignition switch too. It's been happening for a few months hopefully it doesn't get worse and affect driveability. The car is going to be parked for awhile after the end of this month, so I'll have some down time to figure it out.
Old Sep 29, 2011 | 01:52 PM
OK so I did replace the ignition switch and it completely fixed the issue and now about 1 year later its doing it again!! Is it because I did the install bad because I had to rewire the alarm into the ignition switch and I'm kind of scared I might have did a hack job on the wiring causing this problem to come back. But i'm convinced it is probably something else. Any ideas?
Old Sep 29, 2011 | 05:36 PM
fcm's Avatar
fcm
Old Fart
Try the bypass jump or test the start circuit... https://honda-tech.com/forums/showth...&highlight=fcm .94
Old Sep 29, 2011 | 06:57 PM
circlejerk911's Avatar
i have this problem right now as well. sometimes my car will not start for a good 5 minutes, i get lucky i guess. so it may get worse ive been dealing with it for a few months now....
Old Sep 30, 2011 | 02:48 AM
lol you held the key there for 5 minutes? I usually give up after 30 seconds and then i'll try again. But ya do what I did and replace ignition switch if you want to temporarily fix the problem for a year =]
alexdbest
Honda CR-V & Element
12
Dec 23, 2013 03:55 PM
vplukas101
Jan 25, 2013 04:09 AM
invisible
Feb 13, 2009 05:34 PM
fanatic
Nov 5, 2005 06:00 PM
Jet Black
Sep 10, 2003 07:07 PM
