SRS reset plug location 2000 integra
Re: SRS reset plug location 2000 integra (Mazinger)
I found it thanks. If you look at the fuse box, it's on the top right.
I just had so many extra alarm wiring under there that it was hard to find. I could even plug it back in the dummy slot.
Thanks.
Thanks.
Re: (blownmotorking)
i checked the under-dash fuse box. i THINK i can see a small, yellow plug with two green wires coming out. it looks to also have loom over it that is wrapped in yellow tape. it's tucked a bit up there.
would this be the right plug to use?
thanks in advance.
thanks in advance.
Re: (kaj)
http://www.team-integra.net/se...=1128
they used a 2000 gsr as an example i found it.. but i cant seem to find the srs control module becuase apparently im supposed to replace it after the airbags go off
Re: (wlee112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wlee112 »</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/se...=1128
they used a 2000 gsr as an example i found it.. but i cant seem to find the srs control module becuase apparently im supposed to replace it after the airbags go off </TD></TR></TABLE>
its behind the center console, underneath a black plastic cover.
darkmentality
02-06-2013 05:10 PM
