squeaky shocks?
Old Feb 18, 2004 | 06:58 PM
lke2drvgsr's Avatar
Default squeaky shocks?
ive got Tein HA's on my '94 gsr, and i think it's coming from them, but there's a really bad squeaking noise, sorta like a bed during sex (only sound that comes to mind when trying to describe it) anyway, does anyone know what it could be? im about to just spray wd40 all over the car, engine bay, and everywhere i possibly can cuz its really getting annoying
Old Feb 20, 2004 | 08:51 AM
lke2drvgsr's Avatar
Default Re: squeaky shocks? (lke2drvgsr)
no one?
Old Feb 20, 2004 | 08:55 AM
Rory Breaker's Avatar
Are you sure its the shocks and not something in the interior, IE seatbelt buckle, seat, etc?
Old Feb 20, 2004 | 09:33 AM
lke2drvgsr's Avatar
Default Re: squeaky shocks? (newgsrdriver)
nah its clearly coming from somewhere on the outside of the car but near the engine bay... it may be like somewhere under the dash near the firewall or somethin, idk
Old Feb 20, 2004 | 09:36 AM
T3mp3sT's Avatar
I dont know about Teins enough to know their assembly, but when I dropped mine, my camber kit (front) had new bushings and I didn't grease some metal plate well enough on the bushing. I greased it and squeak went away.
Old Feb 20, 2004 | 09:37 AM
lke2drvgsr's Avatar
Default Re: (T3mp3sT)
it was like this awhile ago, then i dropped in a skunk2 camber kit, and it was still exactly the same... thanks for the input tho
Old Feb 20, 2004 | 11:15 AM
lapok25's Avatar
Does it squeek on a slight move or only on bumps? If it squeeks in slight move have one of your friend shake the car while you're checking the engine bay.
Old Feb 20, 2004 | 12:02 PM
lke2drvgsr's Avatar
Default Re: (lapok25)
ya it squeaks like all the time, not even necessarily when the car is bouncing, it's ridiculous ill have someone shake the car tho while im listening, thanks
Old May 18, 2004 | 09:25 PM
GSRacer1's Avatar
Default Re: (lke2drvgsr)
hey I have the same problem
I want to know to
Old May 19, 2004 | 03:54 AM
scrap1ngsr's Avatar
Default Re: (GSRacer1)
ME 3 I have a similar problem with my set-up too
Old May 19, 2004 | 06:56 AM
R6E6I6D's Avatar
Default Re: (CivicSiR94)
2nd gen owner... i had some squeaking coming from the suspension also the way i fixed it was lifted the car on a jack or lift and lowerd it and as it lowerd it squeaked and i found that i needed new tierod ends and bushings on my control arms... but yeah just try whati did i figured out the probelm immediatly after i did this.
Old May 19, 2004 | 07:39 AM
grlstockb18c1's Avatar
Yeah mine are squeaky too...but only when I go over speed bumps and when I hit potholes that I couldn't avoid.
Old May 19, 2004 | 08:50 AM
Devlins 91LS's Avatar
Default Re: (grlstockb18c1)
Lube ur bushings. Thats generally the problem like 99.999999999% of the time
Old May 19, 2004 | 11:11 AM
AnotherGSR's Avatar
I often gat a squeak from the 2 camber kit bolts under the hood by where the shocks bolt in.. I think there a 18 mm bolts, and they loosen just a little bit and I get a squeak when the car bounces over a bump.
My roomate had some squeaking in his 93 hb and it was the same bolts too..
Hope this helps
Old May 24, 2004 | 01:46 AM
T3mp3sT's Avatar
Like i said to begin with, lube the bushing anyhow. cuz that solved it for me and just about everyone else
if it persists, then we'll see whats up
Old May 24, 2004 | 02:56 PM
GSRacer1's Avatar
does anyone have an answer to these questions
Old May 24, 2004 | 03:02 PM
NeoGSR's Avatar
Default Re: squeaky shocks? (GSRacer1)
i have the same problem....i've found wrenchin' the **** outta those two camber bolts along with a lot of silicone spray works for a while (don't use WD40-it's petroleum based and will eat rubber)
as far as a long term fix.....i dunno what else to do?!?!
Old May 24, 2004 | 03:14 PM
Link0's Avatar
Default Re: squeaky shocks? (NeoGSR)
My upper control arm bushings are what's causing my squeaks. Is there any way to lube these and what do you use?
Old May 25, 2004 | 02:30 PM
2G0S0R1's Avatar
New User
Default Re: squeaky shocks? (Link0)
My squeeking from the front end was caused by the rubber insert that is in between the spring and the top cup, replaced them and COVERED them in grease... no more squeeeeeeks.
Old May 25, 2004 | 03:05 PM
b18cu's Avatar
Default Re: squeaky shocks? (2G0S0R1)
I have the flex and they squeak like ****!
But the problem just started one day when i went to the drag strip in carlsbad...it had this really long dirt road...i think thats what did it but not sure tho
Old May 25, 2004 | 03:54 PM
MajorPayne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2G0S0R1 &raquo;</TD></TR><TR><TD CLASS="quote">My squeeking from the front end was caused by the rubber insert that is in between the spring and the top cup, replaced them and COVERED them in grease... no more squeeeeeeks.</TD></TR></TABLE>
yep lots of times the tophats will squeak....chances are thats what it is, if theres no leaks from the shocks, just put some grease btw the rubber tophat bushing and the spring, should do the trick
Old May 25, 2004 | 06:15 PM
b18cu's Avatar
Default Re: squeaky shocks? (MajorPayne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MajorPayne &raquo;</TD></TR><TR><TD CLASS="quote">
yep lots of times the tophats will squeak....chances are thats what it is, if theres no leaks from the shocks, just put some grease btw the rubber tophat bushing and the spring, should do the trick</TD></TR></TABLE>
what if the "tophat" is not rubber
Old May 25, 2004 | 07:49 PM
MajorPayne's Avatar
Default Re: squeaky shocks? (b18cu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cu &raquo;</TD></TR><TR><TD CLASS="quote">
what if the "tophat" is not rubber</TD></TR></TABLE>
not the "tophat" itself, the rubber bushing that is inside it, that the spring touches, they squeak sometimes, why would you have a tophat with no rubber bushing??
Old May 25, 2004 | 08:14 PM
b18cu's Avatar
i thought...wait sorry my bad i know what you are talking about now...
Old May 25, 2004 | 08:17 PM
b18cu's Avatar
my flex's dont have a rubber piece between the spring and the pillow mount...
danielblushtein
Suspension & Brakes
20
Nov 5, 2010 03:51 PM
zither
Oct 4, 2004 04:31 PM
Kazmans94cord
Mar 31, 2002 09:34 PM
CiViC dRaGsTaR
Jun 25, 2001 09:37 PM
