Squeaking Hatch???
Old Jan 7, 2002 | 06:07 PM
Adampops's Avatar
Default Squeaking Hatch???
Ive heard that a lot of tegs have this problem!! I tried to search ways to fix it, but nothing came up!! so, does anybody else have this problem and how did you fix it??
Old Jan 7, 2002 | 06:17 PM
1fastGSR's Avatar
New User
Default Re: Squeaking Hatch??? (Adampops)
I had the latched replaced in my old 96 LS HB under warranty and it went away.
Old Jan 7, 2002 | 07:31 PM
Brian_92GSR's Avatar
New User
I'm also having this problem on my 92 GSR. As soon as I put on my koni yellows and H&R springs the hatch started to squeak.
Old Jan 7, 2002 | 09:17 PM
MrSmith's Avatar
Default Re: Squeaking Hatch??? (Brian_92GSR)
mine was squeaking too but i was finally able to get rid of it. When you pop the hatch there are two rubber things one on either side that you can twist in or out. It basically aligns the hatch. If you twist it out the hatch will be a little higher. I did that and the squeak magically went away.
Old Jan 7, 2002 | 09:23 PM
nfn15037's Avatar
Default Re: Squeaking Hatch??? (MrSmith)
If that doesnt help, try wrapping some electrical tape around the latch. Should cure the squeakage.
thundernoodle
Apr 28, 2010 06:35 PM
zach1288
Jul 20, 2009 12:28 PM
RS Integ
Apr 24, 2004 05:50 AM
Alexander
May 24, 2002 01:03 PM
InfamousRS
Jul 2, 2001 12:39 PM
