spoon flywheel problem
Old Jun 18, 2004 | 08:23 AM
QQ's Avatar
QQ
Default spoon flywheel problem
i have a usmd B18C5 engine and i put the spoon flywheel in it, the problem is when i start the car the flywheel strip.I already change the new starter when i put the flywheel so do i need so modify? coz this is my second spoon flywheel.
Old Jun 18, 2004 | 09:36 AM
HONDA_RACER92's Avatar
Default Re: spoon flywheel problem (QQ)
You should just contact spoon directly they might suggest that you use a different starter. What is happenning is the teeth on the starter are not making good contact with the flywheel. Double check the part number on your starter and make sure you have the correct one. If you give me the part number, year of your car and model I work for Acura and I could check with my parts department to make sure everything is correct. Let me know.
Eric
Old Jun 18, 2004 | 11:27 AM
QQ's Avatar
QQ
Default Re: spoon flywheel problem (HONDA_RACER92)
thx eric my car is 1998 integra R with Denso DXDIV 228000-2050 12V starter, and the starter is rebuild kits so do i need to change? coz my frist flywheel and starter strip already. thank for your help
Old Jun 18, 2004 | 02:00 PM
Well, hopefully this will solve your problem the part number for the stater from acura is 31200-p73a01rm. If you didn't buy the stater from your local acura dealer It could be that the shaft on the starter is actually a different length. See the problem you have right now is that the stater isn't lining up with your new flywheel. This is causing it to chew off the teeth on the flywheel. NOT GOOD AND EXSPENSIVE TO REPLACE! When you remove your starter from your car look at the starter and look for the ware on it. I bet only half or less of it is chewed on. This is good evedenice that the shaft is not long enough. Also, make sure your flywhell is torqued down to the factory specs. Let me know if this helps.
Eric
Old Jun 19, 2004 | 09:15 AM
QQ's Avatar
QQ
Eric i live in canada, and i call honda ,but they say they can't get it. do u have any ways to get one?
Old Jun 19, 2004 | 12:22 PM
Tweakmeister's Avatar
this is a KNOWN problem with the Spoon flywheel...the cut for the teeth is different than USDM.
Go Comptech 6.75lbs AL flywheel next time
Old Jun 21, 2004 | 11:27 PM
QQ's Avatar
QQ
eric i got the starter now so i hope that work fine thx for your help
Old Jun 22, 2004 | 06:04 AM
Before you put all this together I would check the way the teeth come together. You know hold the starter upto the flywheel and make sure that the line up. If the teeth on the flywheel are not 90degree to the starter then you will have the same problem again. And will need to buy another flywheel from someone else. My fav. is the JUN 9lbs. but, there are plenty of others out there. GOOD LUCK!!!
Old Jun 26, 2004 | 10:33 PM
QQ's Avatar
QQ
yet i try it that starter is from the JDM Honda DC2R 97 is totally difference with the usmd once . I mean the gear, so no problem right now since this week. thx a lot
lke2drvgsr
Jun 4, 2004 02:42 PM
mafay2
Feb 23, 2004 07:45 AM
seanb18c1
Feb 22, 2003 11:18 AM
lilcasino
Aug 4, 2002 08:25 AM
quick108
Jul 13, 2002 02:18 PM
