Speedometer problem
Old Oct 6, 2006 | 04:36 PM
teefunk01's Avatar
Default Speedometer problem
if anyones ever had this problem please enlighten me...
speedometer is not working stopped during driving did some research and this is everthing ive checked
I switched 4 vehicle speed sensors already each didnt fix it
Checked the plug..
switch tachs
checked all the grounds
alternator puts out 14.5v
battery is good
car doesnt throw check engine light btw
Still doesnt work.......if anyone knows the problem please let me know or else looks like im vtecless tomorrow
Old Oct 6, 2006 | 04:39 PM
stockb18c's Avatar
speed senor is bad or the wiring is fried...
Old Oct 6, 2006 | 04:43 PM
teefunk01's Avatar
Default Re: (stockb18c)
vss is good....test four different ones.....checking the wiring now
Old Oct 6, 2006 | 09:00 PM
S1NFUL RL1 619's Avatar
Default Re: (teefunk01)
first guess would be the vss, but since you said you tried 4 different ones, then i would check the plugs to see if they're corroded. you said the plugs were good, so the last things would be the wiring... and if all the wires are straight, then you might just need to replace the cluster.
beat
Jun 7, 2010 01:33 PM
sw1fty
Transmission & Drivetrain
Sep 29, 2009 03:27 PM
BlackCatt
Nov 20, 2008 03:58 PM
dvsluder
May 28, 2004 05:42 AM
alexngo
19
Mar 23, 2004 04:23 PM
