Speedometer problem
Old Nov 1, 2005 | 06:32 AM
Turbo94DelSol's Avatar
Default Speedometer problem
After i did my swap into my 00 integra my speedometer stopped working, obviously VTEC isnt working and i tried using different VSS and it still doesnt work and my ecu works fine in another car.....what else can it be? its a brand new trans from acura, could that be a problem??? any posts will help
Old Nov 1, 2005 | 06:34 AM
spoolinyo's Avatar
is th vss installed properly, becuase i thought it was one time and it really wasn't
Old Nov 1, 2005 | 06:43 AM
Default Re: Speedometer problem (Turbo94DelSol)
well yeah it is installed correctly....how can u install it wrong? it has a bolt hole and its screwed in, any other comments??
Old Nov 1, 2005 | 07:53 AM
thegrayghost's Avatar
Try cleaning the connectors with some contact cleaner....maybe just corroded
Old Nov 1, 2005 | 08:31 AM
SSBPGSR's Avatar
Default Re: Speedometer problem (thegrayghost)
this happened to me too, i had a break in the harness somewhere between the VSS and the ecu. i swapped wiring harnesses because i had an extra laying around and it solved the problem. but check for continuity between the VSS and the ECU if u dont have an extra harness
Old Nov 3, 2005 | 06:24 AM
i figured it out, there was a broken pin in the connector.....not it works and VTEC is rippin!!!!
Luserkid
Nov 17, 2012 05:21 PM
Ruben19
Engine Management and Tuning
Sep 1, 2011 11:08 AM
kiko lopov
16
Sep 15, 2009 01:58 AM
accord380whp
Jun 9, 2007 11:29 AM
crispek9
19
Apr 25, 2007 07:41 AM
