Speedometer Help Please Someone...
Old Sep 5, 2007 | 03:38 PM
Random.Hero's Avatar
Default Speedometer Help Please Someone...
I don't post up here very often, but I figured what the heck...
I am currently having a problem with my GS-R cluster. It was working fine before the car went down for about 2.5 months. I fixed the car, started to drive it, and the speedometer itself would jump around, stay at the correct speed, jump some more, and then just 2 days ago, it died completely.
Also, with the cluster acting this way, it is not reading mileage while driving the car.
RPM's, Gas, Engine Temp, etc still all work fine.
Anyone have any experience with this? Did my gauge cluster just die out and it's time for replacement or what?
I recently took it out and checked for any loose connections, etc, but found nothing.
Help would be outstanding at this point...would hate to buy a new one only to have the same problem.
Thoughts? Suggestions?
The cluster has roughly 189,000 on it.
Thanks!
Old Sep 5, 2007 | 11:33 PM
jdmdc22's Avatar
Default Re: Speedometer Help Please Someone... (Bill Gates On Wheels)
If you feel like you're losing power and if your car isn't accelerating as well as it should be than it might be your distributer...
Old Sep 5, 2007 | 11:58 PM
Mfoehrkolb's Avatar
your VSS. vehicle speed sensor. i had the same problem. i broke mine from its own bracket and it was spinning in place. same speed sensor in all b18 series tranns.
Old Sep 6, 2007 | 12:01 AM
Rickdrizzle's Avatar
it happened to my car once, the problem for me was the vss.
Old Sep 6, 2007 | 08:00 AM
Default Re: (Rick to the y)
Thanks for the responses guys.
Anyone have a diagram for replacing this?
Where to buy it?
Thanks in advance!
Old Sep 6, 2007 | 09:01 AM
Mfoehrkolb's Avatar
Default Re: (Bill Gates On Wheels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bill Gates On Wheels &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the responses guys.
Where to buy it?
Thanks in advance!</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=2075255
« Re: Problems with Cluster (Mfoehrkolb) « » 10:48 PM 8/23/2007 Reply Edit
Quote, originally posted by Mfoehrkolb »
---- yuou think its the sensor instead of the cluster itself? cause it still works only @ certain specific times. but barely.
VSS's go out more often than speedometers. But since your check engine light came on, it is most likely for the VSS.
how much does a VSS run?
http://www.acuraoemparts.com/d...ch=no
All the part numbers to the right.
Old Sep 6, 2007 | 05:02 PM
Default Re: (Mfoehrkolb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb &raquo;</TD></TR><TR><TD CLASS="quote">
All the part numbers to the right. </TD></TR></TABLE>
Thank you sir!
However, the link doesn't work for the AcuraOEMParts.com diagram site...
Thanks guys!
Old Sep 6, 2007 | 05:50 PM
Mfoehrkolb's Avatar
thatss cause i cpoied pated. just go on the main website, and go from there. you can find your way to the tranny section.
Old Sep 6, 2007 | 06:07 PM
forumnoobie's Avatar
It is your VSS as earlier stated. Before you go out and replace it. Unplug it and blow it out and plug it back in. I had the exact same problem. Just unplugged it and replugged it back in. Worked fine. If that doesn't help, prob has to be replaced. Good luck.
Old Sep 6, 2007 | 08:31 PM
Mfoehrkolb's Avatar
alot of times with the plug is those wires come out of their caps inside of the harness peice. so just be thuro. and then replace. go to junk yard you can get for cheap.
Old Sep 7, 2007 | 02:02 PM
Thanks for all the help guys! I'll mess with it this weekend!
blinger
11
Mar 26, 2024 08:08 PM
CapnKrunch
Dec 11, 2007 09:09 PM
spaceman00
May 2, 2007 07:27 AM
jdm2teg
Feb 21, 2006 08:38 PM
