Speedometer
Old Jun 10, 2008 | 07:54 PM
inegrakrazy88's Avatar
Default Speedometer
After swapping the engine to b20 the speedometer won't work! ne body have any ideas
Old Jun 10, 2008 | 08:04 PM
BlueIntegraBoy's Avatar
Default Re: Speedometer (inegrakrazy88)
Is the VSS plugged in?
Old Jun 10, 2008 | 11:41 PM
Jimmy's Avatar
Global Moderator
Default Re: Speedometer (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Is the VSS plugged in?</TD></TR></TABLE>
x2.
Also if the VSS is plugged in.. undo the connector and make sure all 3 prongs are intact.. These prongs are known to break and get stuck in the harness plug.. Which would result in a non working vehicle speed sensor.
Old Jun 11, 2008 | 01:48 AM
God-Driven's Avatar
if is cable make sure is all the way in and that the clip is holding it in place, if is ok make sure is pluged in the cluster.
ViSiONxBoY
Jan 14, 2008 04:03 PM
vedha
Nov 10, 2006 08:25 AM
APEX CRX
Jul 27, 2005 01:38 PM
LudeJdm
11
Jun 20, 2005 12:59 AM
sleepin91teg
Mar 29, 2004 04:29 PM
