speed sensor
Old Dec 12, 2011 | 01:57 PM
Pinner13's Avatar
Default speed sensor
just wanted to make sure this was it before i spent the 178.00 on a new one. my speedo was working fine and then all of a sudden driving its pinned at 20mph while driving. if i come to almost a complete stop it bounces around between 17mph and 25mph and when i start driving again it goes back to 20mph
thanks guys
Old Dec 12, 2011 | 02:04 PM
mouab18c1's Avatar
Default Re: speed sensor
Check your ECT ground wire at the thermostat and look for corrosion on your VSS connector.
Old Dec 12, 2011 | 02:10 PM
Pinner13's Avatar
thanks checked the ground, and also pulled plug looked fine
Old Dec 12, 2011 | 03:10 PM
mouab18c1's Avatar
Problem still remains? You can try a different working VSS. Depending on which motor you have the D and B series Vss should be interchangeable if I remember correctly.
Old Dec 12, 2011 | 03:54 PM
TheRealTegger's Avatar
Is your Check Engine light on?
Old Dec 12, 2011 | 04:08 PM
Pinner13's Avatar
no check engine light, i picked up a used vss for 10 buxs. so going to throw it in and see if it fixes it
Old Dec 12, 2011 | 04:12 PM
HondaPartsHero's Avatar
Technical Hero
http://techauto.awardspace.com/vss.html
Mauro87
13
Jul 15, 2012 05:16 AM
kevodean
Feb 22, 2009 06:51 PM
4dr-Si
Sep 14, 2006 05:05 PM
Silvabullet
Jan 5, 2005 02:06 AM
