Spark plug wires?
Old Jun 9, 2002 | 04:33 PM
calteg's Avatar
Default Spark plug wires?
Its about that time again, so I went over to autozone to pick up a new pair of spark plug wires for the ole LS. They wanted $55 for the OEM set
I cant remember what I paid last time, but Im sure as hell it wasn't $55. I can get Bosches for $45...anyone know a non-online place to get the OEM set more cheaply?
Old Jun 9, 2002 | 04:37 PM
GSRaCeRbOI's Avatar
Default Re: Spark plug wires? (calteg)
the bosch shouldnt be bad... have you looked into NGK's? as for where to get OEM wires other than the dealer and not online.. I don't know..sorry.. hahah at least u didn't check Kragen.. they had the Boschs for like $80.. i walked out the door...
Old Jun 9, 2002 | 04:42 PM
revo2001's Avatar
Default Re: Spark plug wires? (GSRaCeRbOI)
whats the benefit of adding new wires besides looks?
Old Jun 9, 2002 | 04:43 PM
IC x Prince's Avatar
New User
my NGK's were $58...But I found that most things I buy for the GSR are more expensive than the other models
Old Jun 9, 2002 | 05:05 PM
GSRaCeRbOI's Avatar
Default Re: Spark plug wires? (UltraGSR)
yeah GSR parts are more expensive.. but he stated he had an LS... so it might be less.. not sure.. I had magnecors... $58 isn't bad for NGKs..
if your car is relatively stock or has minor bolt ons the stock wires are fine and there won't be much if any benefit in replacing them.. however if they are old and in need of replacement then you'll see benefits from replacing them.. otherwise for a lightly modded or stock car.. the stock wires are fine..
Old Jun 9, 2002 | 05:46 PM
calteg's Avatar
So, back to the original question...where can I get cheap wires?!
OEM, Magnacor, NGK, doesn't matter as long as I dont have to shell out $50 for them. Guess I'll give the acura dealer around here a call, but every encounter I've had with them has ended up sucking *****...
Old Jun 9, 2002 | 07:36 PM
B18C-EJ1
Guest
Posts: n/a
I spent $75 for my NGK wires for the ol' gzr.
Old Jun 9, 2002 | 07:44 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: Spark plug wires? (revo2001)
If you get a new ignition coil, cap, and wires, you can get minor improvements. On the other hand, just changing the wire alone (unless they are worn) won't do much if anything at all.
Old Jun 10, 2002 | 12:27 AM
SIK IN DA HED's Avatar
New User
Default Re: Spark plug wires? (JSM)
performance wires are better for less resistance and cracking to the core of the wire.
i recommend NGKs and OEMs for basic boltons.
if you get MSD or you are force fed... get Magnecores, MSD, or Vitek wires.
summitracing sells NGKs and MSD wires for a good price. i got an extra set of Vitek wires for sale. the best ones out there rite now in the market. $90 shipped (compared to $130 at shops and online). send me a message if youre interested in the Vitek wires.
Old Jun 10, 2002 | 12:47 AM
strils's Avatar
Default Re: Spark plug wires? (dlplayboy)
the best deal on NGK's is at inlinefour and price depends on what model teg you got , the LS ones are like $40 and the GSR are around $60, heres the link http://www.inlinefour.com/ngksparplugw.html
[Modified by strils, 4:48 AM 6/10/2002]
Old Jun 10, 2002 | 02:00 AM
B18C-EJ1
Guest
Posts: n/a
Vitek = Best wires?
LOL!
NGK = OEM
OEM = Best fitting
OEM = BEST!!!
Old Jun 10, 2002 | 04:11 AM
TEG98's Avatar
I just bought a set of NGK wires for my ls for $38 from nopi.com
Old Jun 10, 2002 | 07:49 AM
calteg's Avatar
TEG98, did that include shipping?
Old Jun 10, 2002 | 08:31 AM
Tweakmeister's Avatar
http://www.optauto.com
or
http://www.ahmotor.com
Go OEM or NGK
Old Jun 10, 2002 | 08:40 AM
TEG98's Avatar
NO, I think shippong was extra I dont remember the specifics, I ordered a new set of NGK plugs from them too.
Old Jun 10, 2002 | 08:44 AM
junglistgsr's Avatar
Default Re: Spark plug wires? (B18C-EJ1)
Vitek = Best wires?
LOL!
NGK = OEM
OEM = Best fitting
OEM = BEST!!!
actually NGK makes the OEM plugs but not the OEM wires. common misconception.
edit: NGK blues are still what I stick with though.
[Modified by junglistgsr, 9:45 AM 6/10/2002]
Old Jun 10, 2002 | 08:54 AM
calteg's Avatar
Well if the best I can do is $38 plus shipping, I might as well get the Bosches for $45. My engine is bone stock, but it has 65k on it, and this will be the first time the wires have been replaced, so Im expecting a small bump in gas milage.
OT: anyone recommend any trustworthy shops in SoCal? My 70k timing belt + water pump is approaching, and I hear its not worth doing yourself...
Old Jun 10, 2002 | 09:09 AM
70k timing belt replacement? never heard of that....i know you should do it every 90k or 6 years or so.
Old Jun 10, 2002 | 09:42 AM
G2Integrity's Avatar
Default Re: Spark plug wires? (junglistgsr)
Sumitomo are the OEM wires.
Anyone here use the Nology Hot Wires? Are they any good? What about the blue NGK ones?
Old Jun 13, 2002 | 11:19 PM
New User
Vitek = Best wires?
LOL!
NGK = OEM
OEM = Best fitting
OEM = BEST!!!
OEM aint the best just cuz it fits better.
Viteks quality behind their wires speaks for itself. learn more about it before you hate.
EDIT: if a performance wire is what youre lookin for... OEM aint the best way to go. its just a H-T fad that people are sayin that OEM wires are the best. its only if you have minor mods and stock ignition.
[Modified by dlplayboy, 12:20 AM 6/14/2002]
Old Jun 14, 2002 | 07:32 AM
Rory Breaker's Avatar
The OEM Sumitomo wires are sufficient for most applications.
If you want an "upgrade", I would go with NGK's or MSD's.
Old Jun 14, 2002 | 11:15 AM
maxxdout's Avatar
Default Re: Spark plug wires? (newgsrdriver)
if you are able to, or have the tools too, check the resistance in the plug wires, they may still be fine. I have the original wires on my car with 131k on the clock. Everytime i change the plugs or do routine maintanence work. Resistance is still within spec, no cracking, no crimps, and still seat up to the engine fine.
Money's money, save it when you can
Old Jun 14, 2002 | 11:57 AM
ingrate's Avatar
25 Year Member
Vitek = Best wires?
LOL!
NGK = OEM
OEM = Best fitting
OEM = BEST!!!
i beg to differ
http://asia.vtec.net/beystock/tuning/plugcable.html
Old Jun 14, 2002 | 01:07 PM
New User
Default Re: Spark plug wires? (In7egrity)
finally, some debatable rebuttable.
first of all, you cant compare a "generic 8mm silicone" brand to a real brand in hypothetical testing. even in valid testing, engineers are still able to develop better products, already assuming that stock wires are better. if you read up on the materials used in Vitek wires, you will see that they do not only use silicon material in their wires. ive talked to them and they backed up their test results against stock wires. cant always read those articles and assume they are valid for all wires. unless they did comparison tests vs. brand name wires, then i would believe it. if this was the case that stock wires were the better wire... you wouldnt see top dawgs racing with wires such as moroso, vitek, etc. if it was robbin them of spark capability. YEAH! so what do you got to say now!
Old Jun 14, 2002 | 02:10 PM
michaelpr's Avatar
New User
My wires seems to be okay (resistance tests, no sparking, etc.) and after tune-ups, I would still have a hesitation when acceleration, especially when I had something on such as the AC. I couldn't resolve the problem until one day I bought a $55 (from NAPA) set of plugs and the car has been running like a champ ever since!!!!
