spark plug removal
Old Mar 22, 2003 | 04:09 AM
2000gsrsedan's Avatar
Default spark plug removal
not sure if the kid who had the car before me put "anti seize" stuff on the previous plugs...should I attempt to remove them for replacement, or bring it to a shop? What would happen if the tops snapped off on me?
Old Mar 22, 2003 | 06:06 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: spark plug removal (2000gsrsedan)
anti-sieze should make the plugs come out easier, and they will be less likely to get stuck. That's the whole point of using that stuff. Whether you should use it on spark plugs or not I don't know, but they should be easier to get out.
Old Mar 22, 2003 | 06:30 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: spark plug removal (PatrickGSR94)
PatrickGSR94 is right. "Anti"-seize compound will make it easier to take out. I put a little bit on my plugs everytime I change them out. I also use the stuff to lube my poly bushings for my sway bars!
Old Mar 22, 2003 | 06:44 AM
Havokmkr's Avatar
It shouldn't be a problem to get them out whether he did use the anti-seize or not. If you're unsure about breaking them then take it to a shop. I just changed mine yesterday and they were a real pain in the a$$ to get out. Just don't jerk on the wrench, or you'll shatter 'em.
Old Mar 22, 2003 | 01:13 PM
GSRaCeRbOI's Avatar
I don't see how it'd be a problem.. the torque spec is really low <20 ft-lbs or something like that so unless your really weak (not saying you are) you shouldn't have a problem.... go pick up a spark plug socket (which has a rubber grommet to grab the plug out after its unscrewed and a ratchet extension to get into the recessed spark plug wall...
for something so simple even if your an amateur I don't see the point of paying $$$ for a shop to do it... I've had several cars.. and in over 300K of driving over my lifetime (diff cars) and many spark plug changes in diff cars.. I've NEVER had the tops snap off...
Old Mar 22, 2003 | 01:17 PM
Default Re: spark plug removal (GSRaCeRbOI)
thanks all, plugs changed today - everything a-ok.
b20bFourDoorCivicLX
Mar 16, 2012 10:26 PM
nateb22
Apr 30, 2009 12:21 PM
pfork
Jun 22, 2007 07:37 PM
B2FiNiTY
Apr 3, 2003 09:15 AM
wuhungsixxx
Jul 17, 2001 08:49 AM
