Sound system problems
Old Jul 8, 2008 | 12:15 PM
PalmyBlueB20's Avatar
Default Sound system problems
alright, i wired my deck yesterday, its wired good and everything, but there's no power going to it, i checked the fuses, the wires, nothing i just don't get it, it has also affected my light above my head, clock and the whipers when i use windsheild washer . any help would be geartly appreciated, Thanks in advance
-Stephane
Old Jul 8, 2008 | 01:26 PM
Default Re: Sound system problems (PalmyBlueB20)
i still need this asap any opinions or anything will help!
Old Jul 8, 2008 | 02:00 PM
Papa Joe's's Avatar
Did your clock and inter lights work before?
Sounds like a blown fuse! Take the kick panel off by the hood release either your clock, inter lights or radio fuses are blown.
Old Jul 8, 2008 | 02:16 PM
Default Re: Sound system problems (Papa Joe's)
yeah they did, just since i installed it, they stopped, yesterday night i took it out for a drive its then i realised my clock it was super super super dim i could barely see it, ill re-check the fuses, -_- its also a '91
Old Jul 9, 2008 | 09:01 PM
gtec8285's Avatar
i have the same problem but it only happen ever since they stole my deck and i think they yank on the wire so u might have a mess up wiring
i have my deck wired up on the ignition thats the only way i can have my deck on since my wires are mess up
Old Jul 9, 2008 | 09:56 PM
ruffrhyder's Avatar
This is a common problem when installing new decks. Check your BACKUP fuse in the engine compartment. When I worked at a stereo shop, I would get at least one customer a week with this problem.
Old Jul 9, 2008 | 11:01 PM
salomon16's Avatar
Default It's a fuse
Check the fuses again. The best way to check them is to use a multimeter and check both sides of the fuse with the key ON for 12 volts. Sometimes fuses can be bad and not look blown. Also check for missing fuses.
Old Jul 10, 2008 | 01:25 AM
J. Funk's Avatar
Default FV-QR
You [freak]ed something up. Probably a short.
Old Jul 10, 2008 | 06:42 AM
patrick4588's Avatar
Default Re: (ruffrhyder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruffrhyder &raquo;</TD></TR><TR><TD CLASS="quote">This is a common problem when installing new decks. Check your BACKUP fuse in the engine compartment. When I worked at a stereo shop, I would get at least one customer a week with this problem.</TD></TR></TABLE>
x2
blackakkord
Jan 31, 2008 05:46 PM
ilovemydc5
May 20, 2007 07:30 PM
saulgoodyo
Sep 18, 2005 06:37 PM
EF4lyfe
19
Sep 27, 2004 08:43 AM
