Sleeper or not?
Old Jan 14, 2003 | 06:37 AM
  #51
IntEGNYC's Avatar
Default Re: Sleeper or not? (RayRay000)
My sleeper
Old Jan 14, 2003 | 07:27 AM
  #52
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Sleeper or not? (JeremyL)
i never said the cars handled flat out of the box and yes like almost any other car from the factory does have a certain amount of body roll, to say that its excessive is just wrong, try driving a Buick Park Avenue sometime and tell me about body roll
more emphasis should be placed on real handling improvement rather than just minimizing body roll, just because a car doesnt roll doesnt really mean that that by itself makes it a good handling car
No doubt, installing stiffer springs, shocks, and roll bars will definitely cut down on body roll, but if all that is used with stock tires, the car will slide all over the place and handle horribly. You need to upgrade tires AND suspension at the same time to get the most out of each part.
Old Jan 14, 2003 | 07:59 AM
  #53
BabyBadassIntegraGSR's Avatar
Default Re: Sleeper or not? (PatrickGSR94)
Not really. If you think about it, aside from people who want to look cool, most people lower their cars to change the handling characteristic of their car(ie-understeer/oversteer) Stock Integras(R aside) all understeer like a pig at the limit. Just by changing the shocks, springs and rear sway, you not only reduce body roll, but you take most if not all, depending on setup, of the understeer out of the car. So now you have a better handling car, but with the same amount of overall grip. This is where tires come in, get what im saying?
Old Jan 14, 2003 | 08:40 AM
  #54
Jesse H's Avatar
a stock GSR isnt what i would call a rocket but its a pretty fast car
Eh
Stock GSR's aren't slow, but I wouldn't exactly regard them as 'pretty fast cars' either.
Old Jan 14, 2003 | 09:54 AM
  #55
MrJasey's Avatar
Default Re: Sleeper or not? (acatak)
do what u want
Old Jan 14, 2003 | 10:01 AM
  #56
Community Builder
Default Re: Sleeper or not? (BabyBadassIntegraGSR)
well I was talking more from a physics standpoint. With stock suspension, when the car goes through a corner, there is a certain amount of lateral forces (G forces) pushing on the car. Some of these forces are taken in by the suspension (which makes for body roll) and some of it is taken by the tires (overall grip). If you upgrade suspension for less body roll, the suspension is now resisting more of those lateral forces, and so the tires now have to take more of the lateral forces, reducing overall grip. If you upgrade the tires on stock suspension, the tires now resist more of those forces (more overall grip), but now the suspension has to take more of those forces and so the body leans sideways more. If you upgrade all of these things, then all of it resists those forces, so you have less body roll AND increased grip.
Old Jan 14, 2003 | 10:15 AM
  #57
SleepersOwn's Avatar
i voted to take them off ( what a shocker ), just keep it the clean white, drop it, add tints ( IMO, i hate when ppl look at me ) and your good SLEEPERSOWN ! ! !
Old Jan 14, 2003 | 10:20 AM
  #58
tC_Dragon's Avatar
Default Re: Sleeper or not? (ALLMOTORDC2)
take them off my friend.
Old Jan 14, 2003 | 11:30 AM
  #59
integrx's Avatar
New User
to be a sleeper you must be quiet and fast, look stockish. Are you fast enough? to be considered a sleeper?
Old Jan 14, 2003 | 11:38 AM
  #60
LSVTEC408's Avatar
this is my sleeper?
Old Jan 14, 2003 | 01:06 PM
  #61
nfn15037's Avatar
Both are correct, but you can also look at it like this: Upgraded suspension with shitty tires, although it may have a *slight* amount less mechanical grip, will most lilkley produce faster lap times as you will be able to get the car to go where you want it to go. But both are valid points.
[Modified by nfn15037, 2:23 PM 1/14/2003]
Old Jan 14, 2003 | 02:39 PM
  #62
JeremyL's Avatar
Default Re: Sleeper or not? (LSVTEC408)
doesnt lowering too far adversley effect suspension travel?
Old Jan 14, 2003 | 02:47 PM
  #63
4doorRS5spd's Avatar
New User
Yes. That's why you don't see too many track cars that have that "so close to the ground that air can't pass underneath look."
However, touring cars and other race cars are that low, but they have extremely well designed suspension set ups.
Old Jan 14, 2003 | 05:51 PM
  #64
Targa250R's Avatar
be professional
Default Re: Sleeper or not? (4doorRS5spd)
The reason that car looks so high is because of the tires that are on there. I'm willing to be that those are 195/50-15 size tires, in fact I almost guarantee it. Most people buy the 195/50 size because it's cheaper than the OEM 195/55, but the 195/50s have a shorter sidewall and increase wheel gap, not to mention throw off the speedo/odo.
If you want to take away the "4x4 look," without lowering, I'd suggest to spend a little more and buy the proper tire sizes - 195/55-15 or 205/50-15.
Old Jan 14, 2003 | 06:14 PM
  #65
acatak's Avatar
Default Re: Sleeper or not? (Targa250R)
Actually they are 205/50-15
Old Jan 14, 2003 | 06:41 PM
  #66
d15dood's Avatar
sleeper=no stickers
Old Jan 14, 2003 | 08:36 PM
  #67
Got Honda's Avatar
Default Re: Sleeper or not? (au-gsr)
i would take them off
Old Jan 15, 2003 | 05:23 AM
  #68
Targa250R's Avatar
be professional
Well that shoots myy theory all to hell . . .
Are you sure those are 205/50 in that pic? The sidewall is noticeably shorter than my 205/50s . . .
My only suggestion then to take away the "4x4 look" is with an Eibach Pro Kit; it's a pretty mild drop.
Old Jan 15, 2003 | 01:21 PM
  #69
acatak's Avatar
Im 100% sure they are 205/50-15. I will be lowering it with H&R Sports in the spring.
Old Jan 15, 2003 | 11:05 PM
  #70
teg92's Avatar
what exactly is under your hood making it a sleeper and not just a stock GSR with a wing?
Old Jan 16, 2003 | 05:16 AM
  #71
integra-modder's Avatar
I only have the factory emblems on. The VTEC sticker is on my monitor.
Old Jan 16, 2003 | 07:33 AM
  #72
Jesse H's Avatar
Default Re: Sleeper or not? (teg92)
thank you. Somebody else who understands the defination of sleeper.
Old Jan 16, 2003 | 07:56 AM
  #73
Civichatch2k's Avatar
If you took it off yes it may be more sleeper than it is now. But if you like the decals then dont worry about it. Stick with what you like and you cant go wrong!
Old Jan 16, 2003 | 09:17 AM
  #74
d15dood's Avatar
def. needs to be lowered!
Old Jan 16, 2003 | 12:34 PM
  #75
acatak's Avatar
Read my sig.... AEM CAI, DC 421 SS header, thermal stealth exhaust, and in about a week my itr cams, skunk 2 cam gears, and b&M FPR will be in.
