Skunk2 mani on GS-R... idle
Does anybody here with a skunk2 manifold on a gs-r motor have idle problems? My idle is at 1100 and that is the lowest i have gotten it. I even adjusted the idle the right way. I got the info from my Helms...
Re: Skunk2 mani on GS-R... idle (Big Teggie)
already checked for vac leaks. all new gaskets. i even sprayed carb cleaner to make sure there is no leaks. idle screw is all the way tight as well.
Re: Skunk2 mani on GS-R... idle (RedTeg95)
You may need to add more coolant. This is what I noticed when I put mine on.
Re: Skunk2 mani on GS-R... idle (Sleeper)
You only need to pull the fuse for 10sec. Check your tps.
Guest
Posts: n/a
Re: Skunk2 mani on GS-R... idle (B_Cruz)
you can take yr throttle body off.. and adjust the throttle plate with an allen wrench and a 8mm socket. Just be warned though.. a very very slight turn on the allen bolt will affect yr idle quite a bit.. so dont get too happy.
Are you using a itr/ls throttle pulley and cable? If not check if your throttle cable is too tight. Had same problem in my gsr cuz I reused cable.
Re: Skunk2 mani on GS-R... idle (randyman)
idle when my engine is cold is arounc 1100....after engine gets a little heat in it though...goes down to like 700-900 somethin like that
Re: Skunk2 mani on GS-R... idle (Integra_Boi)
must be your IAC (Idle Air Control) did you reconnect all of your sensors? I installed the Skunk2 manifold on my brother's Gsr and it works just like the old manifold did. Let me know what you did so I can help you. No Problems.
[Modified by JUNtypeR, 10:26 AM 6/29/2002]
Re: Skunk2 mani on GS-R... idle (JUNtypeR)
i connected all but the one sensor.. i think its the EVAP sensor.. and also the EVAP tube, i didn't connect cuz the skunk2 dont have a location for it like the stock one.
Re: Skunk2 mani on GS-R... idle (ByronC)
Is your GSR an OBDII. If so, did you T the Evap sensor to the PCV valve line.
I dont know why people have so many problems with the swap. Mine started up and idles perfectly. I guess it's the poor directions skunk provides...
