skunk2 intake manifold problems
Old Mar 31, 2004 | 04:58 PM
gsr98teg's Avatar
Default skunk2 intake manifold problems
i am having a prob with my skunk2 intake mani that i installed yesterday
i am pretty sure that i have everthing in the right spot
when i started the car it idled alright a little high but it hasnt been ran in a while
but when it drops down to a lower idle and you rev it up a bit it goes up and then stays a lot high then it should be at around 2 grand
i do not know what the prob is i m gonna pick up the diagnostics thing from my friend and hook it up
if any of you guys have had this same prob let me know and if and how you fixed it
Old Mar 31, 2004 | 05:00 PM
gapsook's Avatar
Default Re: skunk2 intake manifold problems (gsr98teg)
Try to post pictures and I'll help you.
Old Mar 31, 2004 | 05:16 PM
gsr98teg's Avatar
Default Re: skunk2 intake manifold problems (gapsook)
how do i do that
i have a digital camera but i dont know how i can put them on here
Old Mar 31, 2004 | 05:17 PM
DC2*Integra's Avatar
first upload the pics to a site like imagestation. and then u link it there from here
Old Mar 31, 2004 | 06:35 PM
cjohnson_2's Avatar
do you still have the stock GSR Throttle cable? if so it might be sticking since a lot of the time it hits the hood
Old Mar 31, 2004 | 06:42 PM
Devlins 91LS's Avatar
Default Re: skunk2 intake manifold problems (cjohnson_2)
Make sure your throttle cable isn't too tight, and check for vacuum leaks
Old Apr 1, 2004 | 10:05 AM
gsr98teg's Avatar
Default Re: skunk2 intake manifold problems (Devlins 91LS)
nah i got the itr throttle cable and bracket i dont think its too tight but i'll check it
Old Apr 1, 2004 | 07:00 PM
gsr98teg's Avatar
well i got it everything is good now car is running perfect
i just hadda tighten some vaccuum lines b/c i noticed that they were leakin and then my throttle cable was too tight it was gettin caught up when i let go of the throttle
its all good now thanks
Old Apr 21, 2004 | 09:21 PM
gsrman99's Avatar
vacum leak check seals and if bolts are tight
Old Apr 22, 2004 | 12:19 AM
gundamgsr's Avatar
is it a gsr skunk2 intake manifold? if so it wont work well with your p73 ecu. might want to look into it before you hurt something.
savageevo
Oct 27, 2009 07:42 AM
ganjasnack
May 31, 2009 02:41 PM
dc2_916
Feb 6, 2008 08:39 AM
White GSR '01
Jul 17, 2005 11:17 PM
d_mina
Jul 20, 2004 08:07 AM
