skunk2
Old Feb 19, 2007 | 05:23 PM
acura1808's Avatar
Default skunk2
i have a skunk2 test pipe on my car and it is throwing a check light would that effect the pull on my vtec or no
Old Feb 19, 2007 | 05:26 PM
aaronISthrowed's Avatar
Default Re: skunk2 (acura1808)
1st off you probably shouldn't vtec with a check engine light on, 2nd why not see why the lights on, look in the FAQs and the 1st link will show you how.
Old Feb 19, 2007 | 05:57 PM
blkb18's Avatar
If your car is obd2 (1996 or newer), its most likely throwing a PO420 code for catalyst insufficiency. The o2 sensors are not seeing a change between the front sensor and the rear sensor since there is no converter anymore. This wont effect anything, but it wouldnt hurt to make sure that thats the code before you go beat on it.
Old Feb 19, 2007 | 06:25 PM
qwk db8's Avatar
i think ur car has gone bad u should sell it to me for 100bux and deliver it ill be home all night
Old Feb 19, 2007 | 07:44 PM
JasonST's Avatar
Default Re: skunk2 (qwk db8)
ur probly getting a cel because ur secondary o2 isn't plugged in anymore. It shoudn't hurt much, ur air/fuel might be a little off, but it's probly just ganna be a slight annoyance with the CEL on all the time till u get it fixed.
TheHooded_Mike
22
Apr 19, 2007 04:57 PM
Fat Chick Magnet
Jul 17, 2006 08:56 PM
951dc5
May 29, 2005 04:39 PM
jdmb16ahybrid
Mar 19, 2003 03:07 PM
