Signal Replicator
Old Jan 29, 2005 | 09:47 PM
ckyguy's Avatar
Default Signal Replicator
Does anyone know where I could find a signal replicator (I think they're called), for my o2 sensor that sends a message to the ecu that all is well (instead of throwing a code), that is if anyone even makes them, but for a honda I'd assume so. The cel isn't right btw, it's throwing a code from my testpipe and I'd like it to stop.
Old Jan 30, 2005 | 12:34 AM
The-LS's Avatar
Default Re: Signal Replicator (ckyguy)
I think you may be looking into something like this. Not saying this is the best and only product out there... look around some more and see what comes up.
http://userwww.sfsu.edu/~ecg/o2sim.htm
Old Jan 30, 2005 | 06:38 AM
sykotic's Avatar
why not just chip your ECU and use Uberdata to disable the o2 heater? it will involve changing some maps if you use version 1.7 as the 16bit maps that 1.7 uses run rich. If you use version 1.6 it should be fine.
Old Jan 30, 2005 | 11:57 AM
ckyguy's Avatar
thanks, that's exactly it
Old Jan 30, 2005 | 11:57 PM
The-LS's Avatar
Default Re: (ckyguy)
I know nothing about this but came across it on eBay http://www.o2simulator.com/ a search for "oxygen simulator" came back with some products from them.
Old Jan 31, 2005 | 12:34 AM
Sack Master's Avatar
Default Re: (Black-LS)
We sell o2 simulators at summit racing. I think for hondas they go for about $95. Casper engineering makes them. Definitely a good product for all you obd II guys.
yz125rider21
19
Sep 2, 2006 08:39 AM
draxxus07
Sep 29, 2005 11:35 AM
.ShawnD.
Jan 28, 2004 03:34 PM
Silver_Rex
Nov 3, 2003 07:48 PM
S13 slide
Jun 2, 2002 03:30 PM
