Short Shifter Problems
Old Jul 24, 2002 | 10:19 PM
TEG2001's Avatar
Default Short Shifter Problems
I just installed a B&M short shifter with a shift stabelizer kit in a 2001 Integra. Where the change rod connects to the shift leaver at the joint collar, there is way too much side to side movement when it is in gear, it rattles when slowing down. Any suggestions?? What is this I hear about short shifters screwing with the synchros??
Old Jul 24, 2002 | 10:26 PM
Frito1's Avatar
Default Re: Short Shifter Problems (TEG2001)
the gsr has a short shift already. Just replace the bushings on your stock one to make it more solid.
Old Jul 24, 2002 | 10:30 PM
TEG2001's Avatar
Default Re: Short Shifter Problems (tegsleeper)
If I was running a GSR maybe I would've done that but since I have a GS I decided to switch out.
Old Jul 25, 2002 | 06:34 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
GS and GS-R has the same shifter. Shifts are too long for my taste, especially w/ the butt ugly way too tall stock ****. I don't know about your problem, but I have a generic DC-wannabe shifter that has worked perfectly since I installed it a year ago.
Old Jul 25, 2002 | 11:38 AM
TEG2001's Avatar
Default Re: Short Shifter Problems (PatrickGSR94)
Hey thanks for the info but I found the problem, it was hitting against the heat shield for the cat converter, just had to bend it back, I guess the movement is standard. Thanks for your help
uses0ap
Mar 8, 2010 10:41 AM
cobracmndr
Jul 28, 2008 05:53 PM
DI9ITAL
Feb 8, 2003 09:09 PM
Fuster_Cluck
Oct 8, 2002 02:05 PM
Ekco
Jun 13, 2002 12:36 PM
