shoot nitrous?
Old Jul 9, 2005 | 06:02 PM
kingrd's Avatar
Default shoot nitrous?
i have a 97 gsr. no engine work is done yet, but i do have a long list of things that will happen with time...and money...my friend keeps telling me to shoot it with nitrous and race it, but im afraid that it is going to rip my stock engine apart. what do you all think. should i do it, and what are the possible side effects, and probablitly that they are going to happen. thanks all
Old Jul 9, 2005 | 06:34 PM
purehonda's Avatar
Default Re: shoot nitrous? (kingrd)
nitrous isnt always as bad everyone makes it out to be. making sure the system is installed correctly and tuned so that it doesnt burn too lean while on the bottle is a major factor. it's a fairly cheap way to get some power, but if not used correctly you will melt your motor. Go with a wet system no greater than a 75 shot. I like NX or the Zex systems.
Old Jul 9, 2005 | 06:37 PM
kingrd's Avatar
Default Re: shoot nitrous? (purehonda)
so you think that if i give it like a 50 shot every now and then it will cause no damage?
Old Jul 9, 2005 | 06:40 PM
purehonda's Avatar
you will probably be fine. Make sure everything is up to par as far as plugs, run 91 octane or higher, and I think everything will be okay.
Old Jul 9, 2005 | 06:43 PM
kingrd's Avatar
yea...i run 93 rite now...so its good in that sense...since it is my everyday car i cant let it blow. how much would a wet kit run me
Old Jul 9, 2005 | 08:12 PM
Lewie's Avatar
I'm here for the gangbang!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingrd &raquo;</TD></TR><TR><TD CLASS="quote">so you think that if i give it like a 50 shot every now and then it will cause no damage?</TD></TR></TABLE>
if your motor is in good shape then you should have no problem....i've been running a 50 shot for about 2 yrs now
Old Jul 9, 2005 | 08:14 PM
Lewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingrd &raquo;</TD></TR><TR><TD CLASS="quote">yea...i run 93 rite now...so its good in that sense...since it is my everyday car i cant let it blow. how much would a wet kit run me</TD></TR></TABLE>
cost me about 650 and took a couple of hours to install
Old Jul 9, 2005 | 11:00 PM
apok's Avatar
Default Re: shoot nitrous? (Lewie)
You should upgrade fuel pump/filter/regulator and make sure you have good plugs and wires. On a stock bottom end you should go no more than 50. 75 is pushing it on an LS and probably too much on GSR or Type R blocks.
Just make sure your car is in running order before going with a nitrous oxide system. Its a lot cheaper to prepare your car for more power rather than rebuild your car because of too much power.
116298civic
Honda Civic (2001 - 2005)
12
Mar 2, 2009 06:38 PM
lazyxmofo
May 12, 2008 03:02 AM
The7thG
Feb 4, 2007 08:05 PM
NewbieGuy
Oct 11, 2001 08:24 AM
EVOCELICA
Aug 31, 2001 06:46 PM
