Shock?
Old Jun 20, 2002 | 09:44 PM
yellowbuffalo's Avatar
Default Shock?
do shocks have fluid in them? (stock)
Old Jun 21, 2002 | 06:29 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Shock? (slipknot23)
I think most if not all shocks have fluid in them. Many aftermarket shocks are gas charged, which keeps a high pressure inside the shock. This high pressure helps to keep the fluid inside from foaming and possibly boiling (low pressure = low boiling point, if you get too high in a hot air balloon or something your blood will boil).
Old Jun 21, 2002 | 09:13 AM
threatcon13's Avatar
New User
yes...some have kool aid and some have sunny delight.
Old Jun 21, 2002 | 09:44 AM
Default Re: Shock? (ALLMOTORDC2)
thanks Pat.
J dont be gay
Old Jun 22, 2002 | 01:12 PM
IN VTEC's Avatar
All shocks have fluid (oil) in them. The difference is in the tube design and gas pressure.
There's bi-tube and mono-tube. Bi-tubes have low pressure gas, usually nitrogen, and mono-tubes are high pressure gas filled.
Old Jun 22, 2002 | 01:30 PM
Tweakmeister's Avatar
Default Re: Shock? (IN VTEC)
thought I should add...
you can't refill them by yourself
Old Jun 22, 2002 | 08:15 PM
ChosenGSR's Avatar
Default Re: Shock? (Tweakmeister)
Old Jun 22, 2002 | 08:20 PM
Default Re: Shock? (ChosenGSR)
Old Jun 22, 2002 | 09:34 PM
sutrusu's Avatar
my shocks aren't bi.
Tarmac Junkie
Nov 12, 2008 08:08 PM
icrnk
Apr 22, 2008 02:54 PM
stevey
Suspension & Brakes
Aug 12, 2006 06:13 AM
zeRozeRo L$
Apr 5, 2006 06:24 PM
