Shifter boot question?
Old Aug 29, 2003 | 06:22 PM
Lamska's Avatar
Default Shifter boot question?
Hey guys,
Just a really weird question about the shift boot on my 94 integra. On all other cars i have noticed that the ring on the top of the boot is suppose to be connected somehow by a ring or something to keep it from falling down and exposing the shifter. I don't whether or not its just my car that has that kind of problem, or is there a part missing? So help me out here guys answer this dumb question for me....
thanks...
Old Aug 29, 2003 | 06:41 PM
threatcon13's Avatar
New User
Default Re: Shifter boot question? (Lamska)
with my skunk2 shifter the boot sags a lot ,but it didnt when i had the oem shifter in there.
Old Aug 29, 2003 | 06:43 PM
King_j's Avatar
at the bottom of the shift ****, and at teh top of the shift boot, there is space. like a 1/2 inch of space, this is normal. on integras, the boot is not connected to the shift ****.
Old Aug 30, 2003 | 01:11 AM
Vtecfool's Avatar
Default Re: Shifter boot question? (King_j)
mine also started to sag after installing a replica type r shift ****, looks better this way imo.
Old Aug 31, 2003 | 10:19 AM
Teknic73's Avatar
Default Re: Shifter boot question? (Vtecfool)
you should get the Type R shift linkage, atleast when it sags it has a nice polished shifter to look at.
pic stolen from Skafia
Old Aug 31, 2003 | 12:07 PM
Calavera's Avatar
Default Re: Shifter boot question? (Teknic73)
if you dont want it to sag, use a ziptie to make it stay up. just take off the lower center console because you're gonna need access from underneath the shiftboot. tie a ziptie where you want your top of the shift boot to hang from.
Old Aug 31, 2003 | 12:10 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lamska &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys,
Just a really weird question about the shift boot on my 94 integra. On all other cars i have noticed that the ring on the top of the boot is suppose to be connected somehow by a ring or something to keep it from falling down and exposing the shifter. I don't whether or not its just my car that has that kind of problem, or is there a part missing? So help me out here guys answer this dumb question for me...</TD></TR></TABLE>
Are you using the stock shift ****? The stock **** should snap into the ring on the boot (except on '00/'01 ITR's).
Old Aug 31, 2003 | 04:07 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Shifter boot question? (Padawan)
the ring does not snap into the OEM shift ****, at least not on my 94. The boot sags slightly, but I do have a polished short shifter beneath it.
Although the shifter does get quite hot and sometimes one of my fingers touches the exposed metal part, not fun.
Old Aug 31, 2003 | 04:19 PM
AWDxBOOST's Avatar
the stock shifter screws down to the boot, but the replica type r one that i have leaves about a 1/2 inch of the shifter showin
Old Aug 31, 2003 | 04:24 PM
New User
Default Re: Shifter boot question? (Calavera)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calavera &raquo;</TD></TR><TR><TD CLASS="quote">if you dont want it to sag, use a ziptie to make it stay up. just take off the lower center console because you're gonna need access from underneath the shiftboot. tie a ziptie where you want your top of the shift boot to hang from.</TD></TR></TABLE> I remember someone talking about a grommet that you can use to hold the shifter up as well. BUt since im getting a jdm itr shift linkage, i wont need to deal w/ that.
Old Aug 31, 2003 | 05:13 PM
HiRevn's Avatar
Default Re: Shifter boot question? (Threatcon13)
I have a 95 and the OEM shift **** did not screw to the boot. The shifter did have a rubber grommet/washer on it to keep the boot from going down, but I forgot to put it on when I switched to the B&M "rattler".
Old Aug 31, 2003 | 05:15 PM
philafelman's Avatar
Default Re: Shifter boot question? (HiRevn)
when i put on my aftermarket shift ****, it sagged about an inch. i thought it looked gay, so i put 3 or 4 spacers on the shifter, so the boot couldnt go down, it mounted flush with the ****.
Old Aug 31, 2003 | 08:45 PM
Passaudi1.8t's Avatar
New User
Default Re: Shifter boot question? (philafelman)
I've used this trick on a couple of cars that had the same problem... take off the lower center console, mark off where you want the shift boot to sag til... then take a roll of electrical tape and wrap around the same spot, several times til there is sufficient mass to hold the boot in place. Put everything back together... and magic, your boot won't fall down anymore Nick- who needs another beer after a great night so far.
Old Sep 2, 2003 | 02:06 PM
gsr-2nr's Avatar
Default Re: Shifter boot question? (vtecivicex)
heres an easy way go to kmart take one of the black grommets that sit in the back of a peg hook cut the middle out take off ur console slip that bitch on and put it together if i could figure out how to post a pic id show ya but it fits perect no shifter showing at all
Old Sep 2, 2003 | 02:24 PM
gsr-2nr's Avatar
Default Re: Shifter boot question? (gsr-2nr)
here the finished product
Modified by gsr-2nr at 4:36 PM 9/2/2003
Old Sep 2, 2003 | 02:29 PM
EL Vap133's Avatar
I used a thick rubberband on my shifter, just took off the console, applied the rubber band around the shifter and whoalah!
Old Sep 2, 2003 | 02:33 PM
cyrk007's Avatar
hey,... I have the same thing on my car.. it's relatively normal
galognu
Transmission & Drivetrain
Feb 2, 2016 05:39 PM
xracer6
Dec 18, 2015 07:58 AM
toshko321
10
Oct 5, 2009 08:21 PM
B16Jacques
Sep 20, 2008 09:15 AM
Kellindal
Jan 22, 2002 10:13 AM
