Shifter Assembly
Old Mar 3, 2010 | 10:22 AM
SoTexDC2's Avatar
Default Shifter Assembly
I need to order an OEM shift lever and basically everything but the linkage and bushings. I've done this a few times, but I'm not understanding the parts catalog diagram. Assuming I have nothing but the linkage, do I literally need one of everything listed?
What are all those extra washers and bushings pictured next to the shift lever? Are they included when you purchase a complete shift lever? # 24, 12, 4, 5
http://www.acuraoemparts.com/delray/...ll&vinsrch=yes
Old Mar 3, 2010 | 02:27 PM
TheAsian's Avatar
Default Re: Shifter Assembly
Everything along the shifter yes. W/ out about everything you will have slop and play. You could save some money by ditching the washers and using your own bolt
Old Mar 3, 2010 | 02:43 PM
SoTexDC2's Avatar
My last Integra had a single bolt and a nut that connected the shift lever to the shift rod. I don't remember there being any bushings or washers on the bottom, unless they are pressed inside of the lever itself?
I'm not worried about saving money, I'm trying to make sure that I get everything that was originally installed by Honda/Acura.
Old Mar 3, 2010 | 03:01 PM
SoTexDC2's Avatar
Okay, I guess my other integra didn't have all of the hardware installed. I'll be ordering one of everything.
Should these parts be interchangeable with ITR stuff? AcuraOEMParts has different part numbers for the shift lever, linkage, and a few other things, but the ITR stuff is a bit cheaper than GSR.
Old Mar 3, 2010 | 03:09 PM
Targa250R's Avatar
be professional
What is difficult to understand? That's one of the more straightforward Honda parts diagrams that there are. Yes, you need every single thing listed in the diagram minus the parts that you already have. When you buy a shift lever from Honda, nothing is included but the lever itself. All components must be ordered a la carte unless the diagram indicates that multiple items are included in a kit (nothing in that diagram is labeled as such).
Without all of the O-rings, thrust washers, and collars pictured at the bottom of the shift lever, you're going to have so much freeplay in the shifter that you won't even be able to tell what gear you're in. You could DIY with other materials, but it doesn't sound like you really have the know-how or resources to do that, so your cheapest and easiest option at this point is to just order all of the hardware pictured from a Honda or Acura dealer.
Old Mar 3, 2010 | 03:42 PM
SoTexDC2's Avatar
That diagram was confusing to me at first because prior to building this shell, I was working with a shift lever, nut & bolt, and linkage. I never knew about all of those other washers. Although it never gave me any issues, it is now apparent that my last Integra never had all of the required hardware.
I was trying to figure out if those bushings and such are internal parts that are included when you purchase the shift lever. I think that's a legitimate question.
I am not pinching penny's or looking for a cheaper way. I'm not here because I lack the skills/tools to fabricate my own shifter hardware, either. I'm in the final stages of building a car and trying to make sure that I have certain things exactly the way Honda designed it.
The only question I still have - does anybody know if the ITR shift linkage is interchangeable? I'm aware of the chrome plated shift lever, but what else is different?
Old May 11, 2022 | 05:55 AM
Clarkmr's Avatar
Attachment 111327
Hi please help number 15 16 17 correct name of this bush and size for Honda b18 1998 model
kind regards
Ur2slo
Aug 22, 2013 08:27 PM
civicsi0721
Feb 25, 2009 07:14 PM
sickofitall1113
Apr 8, 2007 06:38 PM
r3sgtec
Feb 3, 2007 01:13 PM
crxzcracer
10
Jun 20, 2004 09:54 PM
