Shift linkage question.
Old May 11, 2006 | 07:21 AM
Panoply's Avatar
Default Shift linkage question.
When i bought this shell it came with the shift linkage seperated from the motor. It looks as if the guy has bent the very end of the linage where the actual shifter connects. Does anyone have a real close picture of that end so i can bend it back into shape. This is for a 94 integra rs. thanks.
Old May 11, 2006 | 07:24 AM
Lan's Avatar
Lan
Default Re: Shift linkage question. (Panoply)
I should have bends in it.
Old May 11, 2006 | 07:29 AM
Panoply's Avatar
Default Re: Shift linkage question. (Lan)
sorry, maybe i didn't explain well enough. i know that it should have bends in it. However where the actual "shifter" connects to the linkage im unsure if that part is bent or straight.
Old May 11, 2006 | 07:41 AM
CleanLikeJdm's Avatar
Hype-R Stalker
If it's Too small/big for the shifter to fit, just bend it the right way.
It's nothing major, and get some type of spacer for the extra open area if it's not much.
Old May 11, 2006 | 07:51 AM
Panoply's Avatar
Default Re: Shift linkage question. (FlatBlackTeg)
so by what your saying, it doesn't really matter the angle that the shifter is actually sitting? just as long as the space where the linkage connects to the shifter is as tight as possible?
Old May 11, 2006 | 06:08 PM
Hype-R Stalker
pretty much, you should atleast make sure they're straight to begin with,
Then bend them around a little if it's too big or small.
Old May 11, 2006 | 06:14 PM
DC2 Mang's Avatar
i bent the **** outta mine puttin my GSR swap it, and with my immense arm of steel i bent it back to fit, jk about the arms of steel, its quite easy to bend back into the spot you want it to be at, just wear gloves because its probably dirty and slippery as hell
Old May 11, 2006 | 06:18 PM
95LssTeg's Avatar
Default Re: Shift linkage question. (JDMdc2lsVtec)
previous owner of my car took the washers out so i bent mine in to get rid of the freeplay.
Old May 11, 2006 | 10:33 PM
Panoply's Avatar
Default Re: Shift linkage question. (95LssTeg)
alright so heres what i did. i basically got it straight enough to where i could get the bolt through both holes, put a nut on it, and tightened it down. Basically it bent the sides in making a tight squeeze on the shifter. Sound about right? Thanks for everyones help.
Old May 12, 2006 | 04:52 AM
DC2 Mang's Avatar
should be fine, there are bearings in the shifter, you can always go back and loosen them up if they are too tight
Old May 12, 2006 | 12:02 PM
Panoply's Avatar
alright cool. thanks for everyones help.
civicsi0721
Feb 25, 2009 07:14 PM
Touge Tuning
Dec 2, 2005 07:00 AM
vtecpoweredsol
11
May 18, 2005 07:56 PM
ichibano
Apr 5, 2003 03:34 PM
