Shift light...odd problem, might be an easy fix.
Old May 23, 2006 | 06:08 PM
OMG THE GOGGLES's Avatar
Default Shift light...odd problem, might be an easy fix.
Well I never ran a shift light in any of my cars, relied on my eyes but grabbed one this week by Proform. I installed it via the Team-Integra tutorial with of course black wire going to ground, red going to accessory plug in fuse box along with an upgraded 15A fuse compared to the normal 10A one, and the green wire being connected behind the guage cluster on the blue wire with silver dots...
Heres the problems:
When ignition key is turned to accessory, it flashes once like it should, and seems like it will work fine. I start car up, and shiftlight stays on, lit up. I set the shift point to 3k rpm, just so I can test it, my cars idle is around 1k so its not being set off by that. The shift light stays on with no lights on, and with my parking lights on, but when I switch my headlights on, it turns off. I take it for a few rides down the street, doesnt go off at the set rpm and just stays off. Everything seems connected fine, wtf.
Car is a 2ooo LS
Old May 23, 2006 | 06:33 PM
Default Re: Shift light...odd problem, might be an easy fix. (gasper44`)
I just moved the Green rpm signal wire from the shift light over to the blue wire in the engine bay, the option 2 of the team integra article, now, it doesn't stay on all the time, however, it doesnt activate at all when I hit the designated RPM. ARGHH!!
Old May 23, 2006 | 07:37 PM
CivicFreak's Avatar
http://autometer.com/download_instruction/470d.pdf
run the accessories light into your cruise button
Old May 23, 2006 | 07:43 PM
Default Re: Shift light...odd problem, might be an easy fix. (CivicFreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFreak &raquo;</TD></TR><TR><TD CLASS="quote">http://autometer.com/download_instruction/470d.pdf
run the accessories light into your cruise button</TD></TR></TABLE>
eh? Why would I do that, I am planning on eliminating cruise control in the near future anyways, or is this the ONLY way it can be hooked up? And how would I run it into that button? OR are you saying running it from the fuse box is what is causing the problem?
Old May 23, 2006 | 07:49 PM
CivicFreak's Avatar
why don't you just run it straight into the ecu itself?
Ecu plug has power, rpm, and ground
Old May 23, 2006 | 08:13 PM
Got a decent picture?, I cannot find any of my repair manuals.
Old May 23, 2006 | 08:30 PM
CivicFreak's Avatar
just tap the power and rpm signal in the ecu, and you can run the ground to any chassis part, hope that help
Old May 24, 2006 | 09:49 AM
Talked to proform..its a bad light...what the expletive
Old May 24, 2006 | 09:59 AM
__oversea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gasper44` &raquo;</TD></TR><TR><TD CLASS="quote">Talked to proform..its a bad light...what the expletive </TD></TR></TABLE>
Old May 24, 2006 | 10:01 AM
Default Re: Shift light...odd problem, might be an easy fix. (Last For One)
I know how to connect the damn thing..but who knows, could have been a stupid mistake you know, but I explained that everything is connected fine and its a bad light..expletive. I am trying to get them to ship first so I can have it by the weekend, I dont do that bs you ship we ship crap. You sold defective product, you will serve customer. Thats how I think it should go.
dizzyek
Jul 6, 2006 10:08 PM
OMG THE GOGGLES
May 23, 2006 06:32 PM
ShakesTheKlown
Jun 15, 2004 06:59 PM
turbociv
Aug 28, 2003 06:48 PM
