Shift Knobs...
Old Jul 31, 2002 | 02:54 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Shift *****...
Ok time for a new shift **** because mine is all worn and look like ish.
Anyone who has the Spoon or Mugen ***** one question before I buy a new one.
Do either the Mugen or Spoon ***** screw on and fit like stock? I just don't want the boot to fall down like I have seen with some of the other ***** out there...TIA
Old Jul 31, 2002 | 02:57 PM
Austin's Avatar
Default Re: Shift *****... (ReBornGSR)
Here you go...
https://honda-tech.com/zerothread?id=242382
and if you wanted new...
https://honda-tech.com/zerothread?id=242383
Austin
Old Jul 31, 2002 | 03:09 PM
Grumpy Old Man
Default Re: Shift *****... (Austin)
Thanks Austin I was going to buy from Mike anyway
I was just wondering about the fit of them on the boot...
Old Jul 31, 2002 | 03:37 PM
Austin's Avatar
Sorry about that...missread your post
I don't believe that the **** has the provision to hold the shift boot up...my solution is to purchase the JDM itr shift boot and leave it be...but that's me.
Old Jul 31, 2002 | 03:45 PM
Grumpy Old Man
Thanks you made me get off my *** and goo look.
I just took off the **** and in fact it doesn't hold the boot up. The boot just stays up on it own. So I guess now I just buy which ever looks better
Old Jul 31, 2002 | 03:46 PM
jonsteR's Avatar
I suggest getting a stock itr **** or a skunk 2 ****. Those heavyweight ***** made a big difference (for me). Its so easy to shift know
Old Jul 31, 2002 | 04:14 PM
speedymon's Avatar
Default Re: Shift *****... (jonsteR)
Really a heavier **** makes a noticeble difference!
Old Jul 31, 2002 | 11:32 PM
rodimus's Avatar
Default Re: Shift *****... (speedymon)
try the RSX aluminum 5 speed ****.
i have it...just try it...trust me...you'll love it.
get it from the dealer...a lil over 40 bucks.
Old Aug 1, 2002 | 01:14 AM
redGSRguy's Avatar
Default Re: Shift *****... (EVOL)
Does the itr **** sit a lot lower theen a stock gsr one?
Old Aug 1, 2002 | 01:22 AM
Calavera's Avatar
Default Re: Shift *****... (redGSRguy)
The heavier the shift ****, the easier/smoother the shifts will be.
Anyways, I don't think the ITR shift **** sits lower than an OEM gsr shift ****. I've seen pics of the ITR one and the shift boot was hanging below exposing the shifter.
However, there's an easy way to fix this ugly appearance. You'll have to take out the shift boot first, (you might as well switch to a JDM red stitched shift boot while you're at it ) then use a zip tie to tie it around the shifter. Then insert shift boot. This way the shift boot top is held up by the zip tie and wont slip down. It'll look like this:
Notice that its in 1st gear, and yet the shift boot does not slip down.
Sorry crappy pic.
Old Aug 1, 2002 | 01:32 AM
vtecdc2's Avatar
Default Re: Shift *****... (Calavera)
i use the zip tie method.. i love it
Old Aug 1, 2002 | 08:52 AM
black_LS's Avatar
Default Re: Shift *****... (HoL Lee SHieT)
zip tie method
Good Idea!! I have the Spoon **** and my boot is saggin, but I'm gonna wait to fix it when I can get a JDM ITR boot
Old Aug 1, 2002 | 09:10 AM
LOwrestling2001's Avatar
Default Re: Shift *****... (black_LS)
OR hehe, u could use a shift boot ring like the Si's or the 97 ITRs that connect to the **** (an Si or prelude SH ****) and the boot basically sticks to the **** and doens't expose the shifter at all, i'm using it like that i think it looks sick.
Old Aug 1, 2002 | 09:13 AM
Aaron M's Avatar
i run a DC *** in gunmetal
my boot exposes the shifter also, prolly cuz of the b&m, is it true that if i get a itr boot it will sit higher and cover the shifter more?
Old Aug 1, 2002 | 09:17 AM
Default Re: Shift *****... (SilverB18C1)
no, it's the zip tie that will make it higher...or use a diff ring...the itr boot only has red stitching.
Old Aug 1, 2002 | 09:19 AM
Aaron M's Avatar
Default Re: Shift *****... (LOwrestling2001)
ahh ic, my cousin has a b&m, itr boot, and spoon ***, and the boot doesnt move at all, it doesnt expose anything, perfect actually. do the spoon **** sit lower on the shifter or something
JDM_WHR
Mar 11, 2010 06:03 PM
JapnseDomsticMkt
Honda Civic (2006 - 2015)
Mar 4, 2010 12:20 PM
Nate13
May 2, 2009 06:32 AM
coreydavis23
Honda Fit
Oct 9, 2007 08:09 AM
es02RS
Honda Civic (2001 - 2005)
15
Dec 9, 2006 07:09 AM
