shaved side molding
Old Feb 12, 2004 | 11:37 AM
shift6th's Avatar
Default shaved side molding
I've been thinking about trying to shave off the side molding on my 2000 integra. I was wondering if anyone knows how to remove it, or if it has to be professionally done at a custom shop. the sides look really clean w/o the molding on the door, any help would be much appreciated.
Old Feb 12, 2004 | 11:43 AM
xSCTYGx's Avatar
Default Re: shaved side molding (jdmb18b)
of course u can remove it...but there will be holes drilled into ur car where the moldings attach...i would leave that work to a professional if it were me..
Old Feb 12, 2004 | 11:51 AM
m R g S r's Avatar
Default Re: shaved side molding (Ajtegra)
Yea, they need to be welded, they may crack if theyre just bondo'ed.
Old Feb 12, 2004 | 12:12 PM
sickbling's Avatar
you can just pop them out.. get a flat head screw driver, wrap it around a rag and carefully pry them. make sure you dont break the clips..and yea i think some welding is needed. bondo will crack. dont do it yourself, have a pro do it. or you can just paint them, dupli color makes good paint that matches our cars real good.
good luck
Old Feb 12, 2004 | 12:47 PM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmb18b &raquo;</TD></TR><TR><TD CLASS="quote">I've been thinking about trying to shave off the side molding on my 2000 integra. I was wondering if anyone knows how to remove it, or if it has to be professionally done at a custom shop. the sides look really clean w/o the molding on the door, any help would be much appreciated. </TD></TR></TABLE> I had this done professionally. Basically they take off the molding, and weld a piece of metal over each hole thats left behind. Then sanded down , and repainted. Since most of the car needs to be repainted if this is done, its best to get the moldings shaved while doing a full paint job, to ensure the color matches perfect.
recon23
Paint and Body
Feb 27, 2008 06:47 AM
Pworld
Paint and Body
12
Jun 14, 2007 04:19 AM
spoonlongblock
Honda Civic (2006 - 2015)
Dec 7, 2006 09:46 AM
[Eg.6]LiLbOy916
Oct 28, 2006 09:23 AM
krew
Jul 19, 2004 07:27 PM
