scraping-> possible rust issues
Old Oct 11, 2002 | 11:55 AM
TEG98's Avatar
Default scraping-> possible rust issues
I just moved and I now scrape every other time into my driveway(I can't go at an angle it is between houses with ~3 inches each side clearance) It sounds pretty solid when I scrape I have yet to get my car up in the air I think the scraping is coming from the frame behind the front wheels(the driveway has a very severe angle) Has anyone in the midwest experienced rust problems because the rust proofing was scraped off their teg. Anys suggestions on how to protect my car.
my car is at stock height
Thanks
[Modified by TEG98, 8:59 PM 10/11/2002]
Old Oct 11, 2002 | 12:23 PM
GSRaCeRbOI's Avatar
Default Re: scraping-> possible rust issues (TEG98)
can't u park outside? or is it a bad area? scraping everyday going in and out of your driveway doesn't sound good to me.. can you put wood blocks where at angles up so that your tires roll up on it and give you more clearance or something?
Old Oct 11, 2002 | 12:57 PM
TEG98's Avatar
Default Re: scraping-> possible rust issues (GSRaCeRbOI)
the rise is about a 60 degree angle an is only 4-5 ft long, putting wooden blocks would not help. The area is not the greatest Had my previos car broken into and hit multiple times on the street. My Friends and I have had no problems when our cars are parked on the steet. The only reason that I do not scrape every time is that I am learning the exact timing I need (slight shock rebound) to not scrape at the bottom or the apex of the hill.
Old Oct 12, 2002 | 10:56 AM
TEG98's Avatar
Default Re: scraping-> possible rust issues (pineapple)
better shocks = less shock bounce and more scraping. any other suggestions
Type R 2c
Mar 19, 2002 08:16 PM
travis
Jan 30, 2002 11:47 PM
IntegraGSRgirl
Audio / Security / Video
14
Jan 20, 2002 07:13 AM
RHGSR01
Sep 22, 2001 07:26 AM
