safc problem
Old Sep 11, 2004 | 09:04 PM
thunteg's Avatar
Default safc problem
anyone know why if you unpluf the safc your car will shut off or not start because my car runs fine with it in but want to sell it but my car wont start if i take it out any ideas?
Old Sep 12, 2004 | 01:18 PM
shrug's Avatar
Default Re: safc problem (thunteg)
you cant just unplug it. you have to disconnect all the wires at the harness and put it all back to stock.
Old Sep 12, 2004 | 01:57 PM
saleensolution's Avatar
Default Re: safc problem (shrug)
you have to plug back up the map sensor and stuff for it to run thats why they came with special connectors to plug them up with
Old Sep 12, 2004 | 02:16 PM
boosted k20's Avatar
Default Re: safc problem (saleensolution)
u need to reconnect the MAP sensor wire and tape up all the splices that were made to the harness. on the SAFC, the white and yellow wires connect to the MAP sensor. when u remove the safc, just join the wire's that the white and yellow wire on the safc were attached too
Ryan559
Sep 2, 2012 08:46 PM
sp00ledbseries
Jan 27, 2009 10:57 AM
Gant
May 18, 2005 08:47 PM
drunknbass
May 8, 2005 12:57 AM
