RPM gauge problems..
Old Nov 9, 2011 | 05:02 PM
JDeez_1212's Avatar
Icon3 RPM gauge problems..
I am new up here and i just recently bought a 95 ls/vtec turbo integra. Well the other day my rpm gauge needle started "bouncing" my car is not reving or anything, the needle just keeps going crazy. I replaced the whole gauge cluster but it still does it. I NEED HELP!
Old Nov 9, 2011 | 05:08 PM
DirtyDA9's Avatar
Default Re: RPM gauge problems..
I believe RPM signal is sent from the distributor. There's your problem, not the cluster.
Old Nov 9, 2011 | 05:14 PM
JDeez_1212's Avatar
So i should replace the distributor?? Is that going to cost a lot?? like i said im new to all this.. sorry for the dumb questions..
Old Nov 9, 2011 | 05:23 PM
DirtyDA9's Avatar
They usually go for $100-$120 used. I would definately go for a used OEM one from someone on here, DON'T buy a knockoff from pepboys or autozone. I forget exactly which part in the distributor but I'm sure you could just buy that for much cheaper the a whole dist. from a honda dealership. But like you said you are new to this so I don't know if you would be able to take apart the distributor yourself to replace it.
Old Nov 9, 2011 | 05:30 PM
JDeez_1212's Avatar
I have an uncle that works on cars and a few friends that do it as well. So as long as i get that part im sure i can find someone to put it in. I thought it could have been the gauge or the wires, but i guess not. Thanks for your help!
Old Nov 9, 2011 | 05:36 PM
DirtyDA9's Avatar
No problem. I just realized it is the igniter that sends the signal, I'm pretty sure. It is a very easy swap. Just two screws and 4 little wires to pull off of it. Try to buy one without the heat-sink, it will be alot cheaper. Just use your old heatsink.
Old Nov 9, 2011 | 05:42 PM
JDeez_1212's Avatar
Alright will do!
Old Nov 9, 2011 | 05:47 PM
fcm's Avatar
fcm
Old Fart
There are no dumb questions, just dumb answers.
As mentioned, the problem is most likely in the distributor, specifically the RPM output from the ICM, [ignition control module or igniter] it is the blue lead at the distributor assembly.
The first thing I would check is the connection of the blue lead to the ICMs RPM output terminal.
This is the ICM...
Here is a good link on how to test/replace the ICM if you need to...
http://www.ozhonda.com/forum/showthr....-Lots-of-Pics!
However, I would start by making sure all the connectors, [pay close attention to the blue lead connector] are "snugly" plugged onto the ICM terminals, if they are loose unplug them and use a set of pliers to "pinch" the connector together a little, [be carefull not to over "pinch" the connector and damage it.
If that does not solve the problem I would next do a continuity test on the blue lead at the ICM, [blue lead connector] and the blue lead in the cluster plug, there should be little or no resistance, [full continuity] at the same time check the continuity to ground, [cars chassis or any good ground point] of the cluster plugs ground, black lead, same thing goes, should be full continuity to ground.
If both are good, replace the ICM before it fails completely, leaving you with a tow bill. 94
Old Nov 9, 2011 | 06:37 PM
JDeez_1212's Avatar
That helps out a lot.. i will hopefully figure it out friday when i am able to work on it again. thanks a lot!
Old Nov 15, 2011 | 11:32 AM
JDeez_1212's Avatar
Well I found out that it was a bad wire going to the distributor, so I'm just going to replace the whole thing rather than tracing the wire.
Old Sep 16, 2012 | 08:03 AM
dat192's Avatar
I know this is real old but did it also make your car sputter and feel as tho there was a lack of power?
Old Sep 16, 2012 | 09:34 AM
el crapitan's Avatar
if those are symptoms you're noticing, follow fcm's testing procedure. a bad icm will definitely cause lack of power/bogging and irratic tach
Daylightly
Jul 30, 2013 08:29 PM
Built4Battle
Aug 10, 2010 05:01 PM
Davidls
Oct 19, 2009 11:56 PM
bOOsted_D16
Mar 19, 2008 09:52 AM
H.A.R.T B18C1EG6
13
Jul 22, 2004 12:11 AM
